Hi!
The qt libs and the assistant binary that come w/ the 3.2 computeprof/bin have bogus references hard compiled:
strings assistant |grep rgunjal
gives me
/home/rgunjal/qt-4.5.2/lib
(same for all libQT* libraries).
This also applies to
~/.config/Trolltech.conf
which is auto-generated upon using computeprof and contains
usr\local\cuda\computeprof\bin\sqldrivers\libqsqlite.so=40502, 0, x86_64
home/rgunjal/qt x11-commercial-src-4.5.1/mkspecs/linux-g+±64 full-config,
2011-01-22T17:03:19
This causes mount requests to /home/rgunjal to show up in security reports (/var/log/*).
NVIDIA should remove these /home/rgunjal references and rebuild the affected files.
(It’s likely not just a Linux annoyance but also exists under Windows given the backlsash paths above.)
Regards,
Frank
