ComputerVision Installation Failed on Target
Can someone help me with this? I have a JetsonTX2 and trying to install SDK components but the Computer Vision (OpenCV, VisionWorks & VPI on Target) keeps on failing.
I believe that the OpenCV is having an error and the others follow. Below is the error message.
14:51:35 INFO: OpenCV on Target - target: *begin sudo apt-get install -y python-dev python-numpy
python-py python-pytest, 5
14:51:35 INFO: OpenCV on Target - target: Reading package lists... 0% Reading package lists... 100%
Reading package lists... Done
14:51:35 INFO: OpenCV on Target - target: Building dependency tree... 0% Building dependency
tree... 0% Building dependency tree... 50% Building dependency tree... 50% Building dependency
tree
14:51:35 INFO: OpenCV on Target - target: Reading state information... 0% Reading state
information... 0% Reading state information... Done
14:51:36 INFO: OpenCV on Target - target: Some packages could not be installed. This may mean
that you have
14:51:36 INFO: OpenCV on Target - target: requested an impossible situation or if you are using the
unstable
14:51:36 INFO: OpenCV on Target - target: distribution that some required packages have not yet
been created
14:51:36 INFO: OpenCV on Target - target: or been moved out of Incoming.
14:51:36 INFO: OpenCV on Target - target: The following information may help to resolve the
situation:
14:51:36 INFO: OpenCV on Target - target: The following packages have unmet dependencies:
14:51:36 INFO: OpenCV on Target - target: python-dev : Depends: libpython-dev (= 2.7.15~rc1-1) but
it is not going to be installed
14:51:36 INFO: OpenCV on Target - target: Depends: python2.7-dev (>= 2.7.15~rc1-1~) but it is not
14:51:36 ERROR: OpenCV on Target - target: E: Unable to correct problems, you have held broken
packages.
14:51:36 ERROR: OpenCV on Target - target: Error: safe apt install failed: sudo apt-get install -y
python-dev python-numpy python-py python-pytest, exit code: 100, retry number: 1
14:51:36 INFO: OpenCV on Target - target: will sleep 10 seconds before next attempt
14:51:46 INFO: OpenCV on Target - target: Reading package lists... 0% Reading package lists... 100%
14:51:47 INFO: OpenCV on Target - target: Building dependency tree... 0% Building dependency
tree
14:51:47 INFO: OpenCV on Target - target: Reading state information... 0% Reading state
14:51:47 INFO: OpenCV on Target - target: Some packages could not be installed. This may mean
that you have
14:51:47 INFO: OpenCV on Target - target: requested an impossible situation or if you are using the
unstable
14:51:47 INFO: OpenCV on Target - target: distribution that some required packages have not yet
been created
14:51:47 INFO: OpenCV on Target - target: or been moved out of Incoming.
14:51:47 INFO: OpenCV on Target - target: The following information may help to resolve the
situation:
14:51:47 INFO: OpenCV on Target - target: The following packages have unmet dependencies:
14:51:47 INFO: OpenCV on Target - target: python-dev : Depends: libpython-dev (= 2.7.15~rc1-1) but
14:51:47 INFO: OpenCV on Target - target: Depends: python2.7-dev (>= 2.7.15~rc1-1~) but it is not
14:51:47 ERROR: OpenCV on Target - target: E: Unable to correct problems, you have held broken
packages.
14:51:47 ERROR: OpenCV on Target - target: Error: safe apt install failed: sudo apt-get install -y
python-dev python-numpy python-py python-pytest, exit code: 100, retry number: 2
14:51:47 INFO: OpenCV on Target - target: will sleep 20 seconds before next attempt
14:52:07 INFO: OpenCV on Target - target: Reading package lists... 0% Reading package lists... 100%
14:52:08 INFO: OpenCV on Target - target: Building dependency tree... 0% Building dependency
tree
14:52:08 INFO: OpenCV on Target - target: Reading state information... 0% Reading state
14:52:08 INFO: OpenCV on Target - target: Some packages could not be installed. This may mean
that you have
14:52:08 INFO: OpenCV on Target - target: requested an impossible situation or if you are using the
unstable
14:52:08 INFO: OpenCV on Target - target: distribution that some required packages have not yet
been created
14:52:08 INFO: OpenCV on Target - target: or been moved out of Incoming.
14:52:08 INFO: OpenCV on Target - target: The following information may help to resolve the
situation:
14:52:08 INFO: OpenCV on Target - target: The following packages have unmet dependencies:
14:52:08 INFO: OpenCV on Target - target: python-dev : Depends: libpython-dev (= 2.7.15~rc1-1) but
14:52:08 INFO: OpenCV on Target - target: Depends: python2.7-dev (>= 2.7.15~rc1-1~) but it is not
14:52:08 ERROR: OpenCV on Target - target: E: Unable to correct problems, you have held broken
packages.
14:52:08 ERROR: OpenCV on Target - target: Unhandled error when running sudo apt-get install -y
python-dev python-numpy python-py python-pytest: E: Unable to correct problems, you have held
broken packages.;
14:52:08 INFO: OpenCV on Target - target: [ Package PreInstall Finished with Error ]
14:52:08 INFO: OpenCV on Target - target: [ NV_L4T_OPENCV_TARGET_POST_INSTALL_COMP
Install took 39s ]
14:52:08 ERROR: OpenCV on Target - target: command terminated with error
14:52:08 SUMMARY: OpenCV on Target - target: First Error: safe_apt_install failed to run.
How do you install these components?
Using SDK manager or apt?
I’m using SDK Manager. I’ve tried couple version (older versions) and the only error I was getting was on ComputerVision (OpenCV specifically) and the other components of ComputerVision is failing as well because of dependency error.
I even tried apt update and upgrade but still the same. I even tried installing OpenCV manually but still giving me dependency errors
Do you also flash the device with the same JetPack version?
Or just install the components?
Yes, I flash the device with the same JetPack version then install SDK components with it.
Sorry for the late response, is this still an issue to support? Thanks
