I’m trying to compute local positions of cloned robots for reinforcement learning.
I used ArticulationView.get_local_poses() and successfully got coordinates of body frame.
However, get_local_poses() function is too slow to use training RL agent.
When I used it, fps drops almost 2000 times lower than not used.
Regarding my problem, could you tell me how to use get_local_poses faster or how to calculate it instead ?
The get_local_poses method is not implemented using the PhysX tensor API.
A faster alternative is to get the world position (via RigidPrimView.get_world_pose) and subtract to it the current environment position (self._env_pose: a property defined in the RLTask.set_up_scene method) as follows:
