Hello. I have the following python scripts made by me. I am wondering if by any chance it can be adjusted to use the gpu computing capabilities. What it does: generates a random 64 characters hash (a to f, 0 to 9) using the secrets.token_hex(32) function and then it applies it to a set of defined rules with known outcome and if it matches all the rules it outputs the matching hash into a file if not it writes the wrong hash in another file. I want to do it using the gpu for much faster computation. Best regards.
import random
import hashlib
import secrets
def writeFile(addString):
txtFile = open(“NOTFOUND.txt”, ‘a’)
txtFile.write(addString)
txtFile.close()
if name == “main”:
whileLoopBreak = True
txtFileRead = open(“NOTFOUND.txt”, ‘a’)
checkIfExist = 0
public_seed = 3314371705
roundList = [‘1176881’, ‘1176882’, ‘1176883’, ‘1176884’, ‘1176885’]
while whileLoopBreak:
tempString = secrets.token_hex(32)
txtFileRead = open(“NOTFOUND.txt”, ‘r’)
for line in txtFileRead:
while tempString == line[0:-1]:
if(tempString != line[0:-1]):
break
txtFileRead.close()
writeFile(tempString + “\n”)
for i in range(0, 5):
hashString = tempString + “-” + str(public_seed) + “-” + roundList[i]
hash_object = hashlib.sha256(hashString.encode())
hex_dig = hash_object.hexdigest()
begToEnd = hex_dig[0:8]
intFromBTE = int(begToEnd, 16) % 15
if intFromBTE == 10 and roundList[i] == roundList[0]:##1
checkIfExist += 1
elif intFromBTE == 4 and roundList[i] == roundList[1]:##2
checkIfExist += 1
elif intFromBTE == 12 and roundList[i] == roundList[2]:##3
checkIfExist += 1
elif intFromBTE == 6 and roundList[i] == roundList[3]:##4
checkIfExist += 1
elif intFromBTE == 8 and roundList[i] == roundList[4]:##5
checkIfExist += 1
if checkIfExist == 5:
checkIfExist = 0
txtFile = open(“serverSeedFound.txt”, ‘a’)
txtFile.write(tempString + “\n”)
print(tempString)
txtFile.close()
else:
checkIfExist = 0
