I’ve been trying to implement an algorithm that requires the computation of a few max values.
The exact same algorithm works in serial but it doesn’t work on cuda.
The code looks something like this:
/this is in the Kernel function/
float max = 0.0;
for(int i=0; i<GetElement(elem,node); i++)
float qq = GetEl(q, GetElement(NEList, node*maxelems+i));
if (max < qq)
max = qq;
q[node] = max;
After this sequence q is left unchanged leading me to believe that assigning max to q[node] is somehow illegal as a consequence of max being computed incorrectly. If I assign any other value to q[node] (1.0 for example or another float) then q changes.
I have no idea why this is the case. Any help welcome.
You are probably going to have to post a bit more of your kernel to get a definitive answer, but the obvious possibility is a memory race on q[node]. If more than one thread can write into q[node] at the same time, then the results will be completely unpredictable.
I have a thread for each node so there is only one writing going on at q[node].
And also the nodes i am reading are nodes that are not being written to because that’s what the algorithm handles.
The full Kernel function is as follows:
global void kernelSMOOTH(float *q, float x, float y, float metric, const int samecol, const int adj, const int deg, int maxdeg, const int ENList, const int * NEList, const int elem, int maxelems, int nodes, int elems,int cols,int sign,float *max)
int tid1 = threadIdx.x + blockDim.x*blockIdx.x; //index in samecol of node
int nid = -1;
if (tid1 >= cols) return;
int node = GetElement(samecol,tid1); // id of node
float alpha = 0.5;
//initialise max with the value of the maximum functional of the adjacent elements
float max = 0.0;
if (max < qq)
max = qq;
//now try to find a new position for the current node
//recompute quality of the adjacent elements and get the max quality
float maxq = -1;
for(int j=0; j<GetElement(elem,node); j++)
int currel = GetElement(NEList, node*maxelems + j);
int k;
for(k = 0; k<3; k++)
if (GetElement(ENList,3*currel + k)==node)
break;
//k holds the id of my current node
//id1 and id2 hold the ids of the 2 neighbouring nodes
int id1 = GetElement(ENList, 3*currel + (k+1)%3);
int id2 = GetElement(ENList, 3*currel + (k+2)%3);
//float qq = computeQual2(GetEl(x,id1),GetEl(y,id1),&(metric[4*id1]),GetEl(x,id2),GetEl(y,id2),&(metric[4*id2]),xx,yy,m1,m2,m3,m4);
float area = computeArea(x[id1],y[id1],x[id2],y[id2],xx,yy);
float qq;
if ((sign == 1 && area > 0) || (sign == -1 && area < 0))
qq = computeQual3(GetEl(x,id1),GetEl(y,id1),GetEl(metric,4*id1),G
if (maxq < qq)
maxq = qq;
else
illegal = 1;
break;
//maxq holds now the max quality of this new position
//test it against the old max and see if it's better
if (illegal == 0 && maxq < GetEl(max,node) && maxq > -1)
SetEl(max,node,maxq);
nid = neigh;
//for this movement towards neighbour go through all it's adjacent elements and recompute the quality with the new coordinates
//find the maximum quality out of all the ones computed and put it in 'max'
//max will be a valuie that i will have to remember along with the id of the neighbour node
//i will have to compare it with the previous maxs found and if it's lower than the best functional so far then i will
//have to remember it along with the neighbour id.
//if nid is diffrent from -1 then it means that a new better position has been found
int k;
if (GetElement(ENList, 3*currel + k)==node)
break;
SetEl(q, currel, computeQual3(GetEl(x,id1),GetEl(y,id1),GetEl(metric,4*id1),G
Basically it doesn’t make any changes to q because i think it doesn’t compute max correctly and therefore the variable nid is also computed incorrectly. Both max and nid behave in the same way. As soon as I try to use the values in nid or max then the program doesn’t change q anymore.
