Just wondering if anyone has run into the issue where you can only playback one device at a time on the nano through the default asound configuration file that is included with L4T. We are using mpg123 to play audio files in our application, and this limitation was causing problems as the app would crash if the audio device was in use. We were able to work around it using a custom asound / dmixer setup below (replaced the default asound.conf with thisfile) but wondering if anyone else has had got it working through another means?
# Custom asound configuration to allow for multiple concurrent audio streams playing
pcm.dmixed {
type dmix
ipc_key 1024
ipc_key_add_uid 0
slave {
pcm "hw:tegrahda,3"
channels 2
rate 48000
pcm.dsnooped {
type dsnoop
ipc_key 1025
slave {
pcm "hw:tegrahda,3"
channels 2
rate 48000
pcm.duplex {
type asym
playback.pcm "dmixed"
capture.pcm "dsnooped"
# Instruct ALSA to use pcm.duplex as the default device
pcm.!default {
type plug
slave.pcm "duplex"
ctl.!default {
type hw
card Tegra
