My program has multiple threads reading (not writing) elements from std::vector using operator. All it is doing is assigning a temporary variable to the requested element of the vector. When I comment out this read, everything works fine. When it’s in the code, however, the program runs for an arbitrary amount of time and then quits with the following output:
Assertion failed in file "../../port/edgsrc.3.3/throw.c", line 1192
Aborted
I am using version 5.2 of the compiler. Any ideas?
Scott Kilpatrick
