Config deepstream parallel consumer topic
• Hardware Platform (Jetson / GPU) 4090
• DeepStream Version 7.0
• TensorRT Version
When testing with the sample tritonclient/sample/configs/apps/vehicle_lpr_analytic from this repository, I encountered the following issues:
I have four video sources, which are processed in three branches:
  • Branch 1: Sources 0, 1, 2
  • Branch 2: Sources 1, 2, 3
  • Branch 3: Sources 1, 2, 3
How can I configure config_metamux0.txt, msg-broker-comp-id, and msg-conv-comp-id so that each branch publishes messages to a separate Kafka topic?
I try to use one sink, it can use msg-conv-comp-id to filter but it only works for one topic, when I scale to 3 topics (3 sink type 6), it doesn’t work.
Expected Behavior:
  • Topic 1Branch 1 (Receives messages only from sources 0, 1, 2) (inference result with model in branch 1)
  • Topic 2Branch 2 (Receives messages only from sources 1, 2, 3)
  • Topic 3Branch 3 (Receives messages only from sources 1, 2, 3)
In other words, each topic should receive messages only from the sources within its corresponding branch when inferencing with that branch.
Current NVIDIA-AI-IOT/deepstream_parallel_inference_app: A project demonstrating how to use nvmetamux to run multiple models in parallel. sample does not support multiple msgconv+msgbroker. You can modify the code to support it. The sample is in /opt/nvidia/deepstream/deepstream/sources/apps/apps-common/src/deepstream-yaml/deepstream_sink_yaml.cpp and /opt/nvidia/deepstream/deepstream/sources/apps/apps-common/src/deepstream_sink_bin.c
