Hello. Problem with driver version 390.143. The config does not work, I recreate it with the nvidia-xconfig command, so the system does not start at all.
➜ ~ rpm -qa | grep nvidia
x11-driver-video-nvidia390-390.143-1.x86_64
dkms-nvidia390-390.143-1.x86_64
nvidia-additional-settings-1-6.noarch
nvidia390-doc-html-390.143-1.x86_64
➜ ~ neofetch
ROSAROSAROSAROSAR nikolanp@nikolanp-desktop
ROSA AROS -------------------------
ROS SAROSAROSAROSAR AROS OS: ROSA Desktop Fresh R12 release 20
RO ROSAROSAROSAROSAROSAR RO Kernel: 5.10.39-generic-2rosa2019.1-x
ARO AROSAROSAROSARO AROS ROS Uptime: 27 mins
ARO ROSAROS OSAR ROSA ROS Packages: 2925 (rpm)
RO AROSA ROSAROSAROSA ROSAR RO Shell: zsh 5.8
RO ROSAR ROSAROSAROSAR R ROSARO RO Resolution: 1024x768
RO ROSA AROSAROSAROSA AR ROSARO AR DE: Xfce 4.16
RO AROS ROSAROSAROSA ROS AROSARO AR WM: Xfwm4
RO AROS ROSAROSARO ROSARO ROSARO AR WM Theme: Vertex-Light-Rospo
RO ROS AROSAROS ROSAROSA AROSAR AR Theme: Vertex-Light-Rospo [GTK2], Adw
RO ROSA ROS ROSAROSAR ROSARO RO Icons: rosa [GTK2], Adwaita [GTK3]
RO ROS AROSAROSAROSA ROSARO AR Terminal: xfce4-terminal
ARO ROSA ROSAROSAROS AROSAR ARO Terminal Font: Monospace 12
ARO OROSA R ROSAROS ROS CPU: AMD FX-6300 (6) @ 3.500GHz
RO AROSAROS AROSAROSAR RO GPU: NVIDIA GeForce GT 630
AROS AROSAROSAROSARO AROS Memory: 1935MiB / 7855MiB
ROSA SARO
ROSAROSAROSAROSAR
01:00.0 VGA compatible controller: NVIDIA Corporation GF108 [GeForce GT 630] (rev a1) (prog-if 00 [VGA controller])
Subsystem: Gigabyte Technology Co., Ltd Device 3544
Flags: bus master, fast devsel, latency 0, IRQ 52, NUMA node 0
Memory at fd000000 (32-bit, non-prefetchable) [size=16M]
Memory at f0000000 (64-bit, prefetchable) [size=128M]
Memory at f8000000 (64-bit, prefetchable) [size=32M]
I/O ports at e000 [size=128]
Expansion ROM at 000c0000 [virtual] [disabled] [size=128K]
Capabilities:
Kernel driver in use: nvidia
Kernel modules: nvidiafb, nouveau, nvidia_drm, nvidia
