I’m attempting to connect a 9271 serializer to the Drive PX 2. In a sense, I’m performing a custom camera type application, but the 9271 is being driven by an FPGA generating the frame data instead of a camera. I’m using the camera_gmsl_custom as the basis for my initial work and I’m attempting to create the camera config file. I have some questions.
Is there any documentation of what the different config tokens do and what settings are supported? I figure it should be fairly straightforward as long as my 9271 is setup correctly for the PX 2, but I don’t see much in the way of detailed documentation.
Thanks for the response. I’ve seen that documentation. The problem is that the struct doesn’t have any documentation of its contents. I can figure out most of them, but the following elude me.
