• Hardware Platform (Jetson / GPU) GPU
• DeepStream Version 5.0
• TensorRT Version 7.0
• NVIDIA GPU Driver Version (valid for GPU only) NVIDIA-Linux-x86_64-450.80.02
• Issue Type( questions, new requirements, bugs) bugs
Hello,When I run the command: ./deepstream-test2-app sample_720p.h264
I got the log as below:
With tracker
Unknown key ‘enable-past-frame’ for group [tracker]Now playing: sample_720p.h264
gstnvtracker: Loading low-level lib at /opt/nvidia/deepstream/deepstream-5.0/lib/libnvds_nvdcf.so
gstnvtracker: Batch processing is ON
gstnvtracker: Past frame output is OFF
[NvDCF] Initialized
WARNING: …/nvdsinfer/nvdsinfer_func_utils.cpp:36 [TRT]: Current optimization profile is: 0. Please ensure there are no enqueued operations pending in this context prior to switching profiles
0:00:04.534692058 4852 0x5588b56b98c0 INFO nvinfer gstnvinfer.cpp:619:gst_nvinfer_logger: NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::deserializeEngineAndBackend() <nvdsinfer_context_impl.cpp:1701> [UID = 1]: deserialized trt engine from :/opt/nvidia/deepstream/deepstream-5.0/samples/models/Primary_Detector/resnet10.caffemodel_b1_gpu0_int8.engine
INFO: …/nvdsinfer/nvdsinfer_model_builder.cpp:685 [Implicit Engine Info]: layers num: 3
0 INPUT kFLOAT input_1 3x368x640
1 OUTPUT kFLOAT conv2d_bbox 16x23x40
2 OUTPUT kFLOAT conv2d_cov/Sigmoid 4x23x40
0:00:04.534811871 4852 0x5588b56b98c0 INFO nvinfer gstnvinfer.cpp:619:gst_nvinfer_logger: NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:1805> [UID = 1]: Use deserialized engine model: /opt/nvidia/deepstream/deepstream-5.0/samples/models/Primary_Detector/resnet10.caffemodel_b1_gpu0_int8.engine
0:00:04.536298154 4852 0x5588b56b98c0 INFO nvinfer gstnvinfer_impl.cpp:313:notifyLoadModelStatus: [UID 1]: Load new model:dstest2_pgie_config.txt sucessfully
Running…
I’ve configed the enable-past-frame=1 in the file /opt/nvidia/deepstream/deepstream/sources/apps/sample_apps/deepstream-test2/dstest2_tracker_config.txt
Here is my dstest2_tracker_config.txt
[tracker]
tracker-width=960
tracker-height=544
gpu-id=0
#ll-lib-file=/opt/nvidia/deepstream/deepstream-5.0/lib/libnvds_mot_klt.so
ll-lib-file=/opt/nvidia/deepstream/deepstream-5.0/lib/libnvds_nvdcf.so
ll-config-file=tracker_config.yml
enable-batch-process=1
enable-past-frame=1
and I also modified useBufferedOutput: 1 in \opt\nvidia\deepstream\deepstream-5.0\samples\configs\deepstream-app\tracker_config.yml
So, Is “Unknown key ‘enable-past-frame’ for group [tracker]” a bug or my config has something wrong?
