• Hardware Platform (Jetson / GPU) - Tesla T4 • DeepStream Version - 6.2 • JetPack Version (valid for Jetson only)
**• TensorRT Version - 8.5.2.2 ** • NVIDIA GPU Driver Version (valid for GPU only) - 525.85.12 • Issue Type( questions, new requirements, bugs) - Query • How to reproduce the issue ? (This is for bugs. Including which sample app is using, the configuration files content, the command line used and other details for reproducing) • Requirement details( This is for new requirement. Including the module name-for which plugin or for which sample application, the function description)
I am trying to run my application where I make multiple inferences on a single input stream. I am trying to do this using gstreamer command line.
In order to do this, I just added “nvinfer config-file-path=<path-to-config_infer_secondary_carcolor.txt” after the “nvinfer config-file-path=<path-to-config_infer_primary.txt>” command. This however fails, with the error -
0:00:16.539753498 122 0x56416f305d30 ERROR nvinfer gstnvinfer.cpp:674:gst_nvinfer_logger: NvDsInferContext[UID 0]: Error in NvDsInferContextImpl::initialize() <nvdsinfer_context_impl.cpp:1185> [UID = 0]: Unique ID not set
0:00:16.539787593 122 0x56416f305d30 WARN nvinfer gstnvinfer.cpp:888:gst_nvinfer_start: error: Failed to create NvDsInferContext instance
0:00:16.539796726 122 0x56416f305d30 WARN nvinfer gstnvinfer.cpp:888:gst_nvinfer_start: error: Config file path: <path-to-config_infer_secondary_carmake.txt>, NvDsInfer Error: NVDSINFER_CONFIG_FAILED
I have not made any changes in the respective file. Can you please suggest if I am giving the wrong command or there is some issue with the file itself?
Thank you for the suggestion. It seems that the issue was indeed coming because of the absence of the “gie-unique-id” value in the config file. Adding the same is not showing the error anymore.
After adding the “gie-unique-id” value in the respective config file, the error is not coming anymore. However, when I run the above command for my application, I do see the first inference and the tracker information but not the second inference.
I did compare my local sgie config file with the deepstream2 tutorial’s and I have put all the required files. Is there something else I might be missing?
Found the issue. It seems that the other inferences were only coming when the object moves closer to the camera.
However, I observed that the second inference doesn’t appear if I remove the tracker. I don’t seem to have put any tracker specific setting and thus, am confused why am I observing this.
Does bounding-box always exist? BBox is related with your model, sample model only work fine on sample streams.If the BBox is not exist,sgie can’t give a label. The output of tracker is the input of sgie.
Anyway, make sure pgie generates the bbox correctly.
Yes, the boxes appear even if I only run the primary model. Adding the tracker adds the object ID along with the object. If I keep the two and then add the second model, I see its information as well.
However, if I run the second model without the tracker, the boxes still appear identifying the object but don’t make the second inference. Since even just with the primary model, I can see bounding boxes, the issue should not appear after the removing the tracker right?
1.Value of process-mode in dstest2_sgie1_config is 2.
It’s a secondary gie, the input is tensor not video frame. you can refer this document
Tracker can convert data of pgie into tensor. so tracker is necessary.
Secondary mode: Operates on objects added in the metadata by upstream components.
When the plugin is operating as a secondary classifier in async mode along with the tracker, it tries to improve performance by avoiding re-inferencing on the same objects in every frame. It does this by caching the classification output in a map with the object’s unique ID as the key. The object is inferred upon only when it is first seen in a frame (based on its object ID) or when the size (bounding box area) of the object increases by 20% or more. This optimization is possible only when the tracker is added as an upstream element.
2.If you modify value of process-mode to 1.Due to model limitations,it can’t work fine.
CarColor support tensor input only,no work for video frame.
If you want run the sgie without the tracker,modify dstest2_sgie1_config.yml
