• Jetson Nano B01
• DeepStream 5.1
• JetPack Version 4.5
• TensorRT Version 7.1.3
• Question type
• Requirement details: Configure a pin
I am using a module connected to Jetson using UART communication.
Sometimes, I need to restart the module where I just need to connect the RST (Reset) module PIN to Ground. So, In jetson I configurated a GPIO pin initialized as HIGHT:
PIN_7 = 7
GPIO.setmode(GPIO.BOARD)
GPIO.setup(PIN_7, GPIO.OUT, initial=GPIO.HIGH)
When I need to reset the module, I just put this pin as LOW for a while:
GPIO.output(PIN_7, GPIO.LOW)
time.sleep(1)
GPIO.output(PIN_7, GPIO.HIGH)
So, the reset is not executed.
When I do the reset manually, in normal working mode, the RST module pin is not connected anywhere. When I want to restart, I connect this pin to GND pin for a while and the module restart then I disconnect them.
I would like to know what i am doing wrong.
