ConfigStore schema with the same name
• Hardware (NVIDIA RTX 3080 Ti)
• Network Type (Deformable_detr)
• TLT Version (tao info
Configuration of the TAO Toolkit Instance
task_group: [‘model’, ‘dataset’, ‘deploy’]
format_version: 3.0
toolkit_version: 5.5.0
published_date: 08/26/2024
• Training spec file(
train:
num_gpus: 1
num_nodes: 1
validation_interval: 1
optim:
lr_backbone: 2e-5
lr: 2e-4
lr_steps: [10, 20, 30, 40]
momentum: 0.9
num_epochs: 1
precision: fp32
dataset:
train_data_sources:
- image_dir: /tao-pt/nvidia_tao_pytorch/cv/deformable_detr/train2017
json_file: /tao-pt/nvidia_tao_pytorch/cv/deformable_detr/instances_train2017.json
val_data_sources:
- image_dir: /tao-pt/nvidia_tao_pytorch/cv/deformable_detr/val2017/
json_file: /tao-pt/nvidia_tao_pytorch/cv/deformable_detr/instances_val2017.json
num_classes: 91
batch_size: 4
workers: 8
augmentation:
fixed_padding: False
model:
backbone: resnet_50
train_backbone: True
pretrained_backbone_path: /tao-pt/nvidia_tao_pytorch/cv/deformable_detr/resnet50_nvimagenetv2.pth.tar
num_feature_levels: 2
return_interm_indices: [1, 2]
dec_layers: 6
enc_layers: 6
num_queries: 300
with_box_refine: True
dropout_ratio: 0.3
• How to reproduce the issue ? (
deformable_detr# python scripts/train.py --config-path /tao-pt/nvidia_tao_pytorch/cv/deformable_detr/experiment_specs --config-name train.yaml --cfg job
/tao-pt/nvidia_tao_pytorch/cv/deformable_detr/scripts/train.py:142: UserWarning:
‘train.yaml’ is validated against ConfigStore schema with the same name.
This behavior is deprecated in Hydra 1.1 and will be removed in Hydra 1.2.
See https://hydra.cc/docs/next/upgrades/1.0_to_1.1/automatic_schema_matching for migration instructions.
main()
encryption_key: null
results_dir: /results
wandb:
enable: true
project: TAO Toolkit
entity: ‘’
tags:
  • training
  • tao-toolkit
    reinit: false
    sync_tensorboard: false
    save_code: false
    name: TAO Toolkit training experiment
    model:
    backbone: resnet_50
    num_queries: 300
    cls_loss_coef: 2.0
    bbox_loss_coef: 5.0
    giou_loss_coef: 2.0
    with_box_refine: true
    num_select: 300
  • 1
  • 2
    focal_alpha: 0.25
    clip_max_norm: 0.1
    nheads: 8
    dropout_ratio: 0.3
    hidden_dim: 256
    enc_layers: 6
    dec_layers: 6
    dim_feedforward: 1024
    dec_n_points: 4
    enc_n_points: 4
    aux_loss: true
    dilation: false
    train_backbone: true
    loss_types:
  • labels
  • boxes
    backbone_names:
  • backbone.0
    linear_proj_names:
  • reference_points
  • sampling_offsets
    dataset:
    train_sampler: default_sampler
    train_data_sources:
  • image_dir: /tao-pt/nvidia_tao_pytorch/cv/deformable_detr/train2017
    val_data_sources:
  • image_dir: /tao-pt/nvidia_tao_pytorch/cv/deformable_detr/val2017/
    test_data_sources: null
    infer_data_sources: null
    batch_size: 4
    workers: 8
    pin_memory: true
    dataset_type: serialized
    num_classes: 91
    eval_class_ids: null
    augmentation:
    scales:
    • 480
    • 512
    • 544
    • 576
    • 608
    • 640
    • 672
    • 704
    • 736
    • 768
    • 800
      input_mean:
    • 0.485
    • 0.456
    • 0.406
      input_std:
    • 0.229
    • 0.224
    • 0.225
      train_random_resize:
    • 400
    • 500
    • 600
      horizontal_flip_prob: 0.5
      train_random_crop_min: 384
      train_random_crop_max: 600
      random_resize_max_size: 1333
      test_random_resize: 800
      fixed_padding: false
      fixed_random_crop: null
      train:
      num_gpus: 1
      gpu_ids:
  • 0
    num_nodes: 1
    seed: 1234
    cudnn:
    benchmark: false
    deterministic: true
    num_epochs: 1
    checkpoint_interval: 1
    resume_training_checkpoint_path: null
    results_dir: null
    freeze:
    pretrained_model_path: null
    clip_grad_norm: 0.1
    is_dry_run: false
    optim:
    optimizer: AdamW
    monitor_name: val_loss
    lr: 0.0002
    lr_backbone: 2.0e-05
    lr_linear_proj_mult: 0.1
    momentum: 0.9
    weight_decay: 0.0001
    lr_scheduler: MultiStep
    lr_steps:
    • 10
    • 20
    • 30
    • 40
      lr_step_size: 40
      lr_decay: 0.1
      precision: fp32
      distributed_strategy: ddp
      activation_checkpoint: true
      verbose: false
      evaluate:
      num_gpus: 1
      gpu_ids:
  • 0
    num_nodes: 1
    checkpoint: ???
    results_dir: null
    input_width: null
    input_height: null
    trt_engine: null
    conf_threshold: 0.0
    inference:
    num_gpus: 1
    gpu_ids:
  • 0
    num_nodes: 1
    checkpoint: ???
    results_dir: null
    trt_engine: null
    color_map: null
    conf_threshold: 0.5
    is_internal: false
    input_width: null
    input_height: null
    outline_width: 3
    export:
    results_dir: null
    gpu_id: 0
    checkpoint: ???
    onnx_file: ???
    on_cpu: false
    input_channel: 3
    input_width: 960
    input_height: 544
    opset_version: 17
    batch_size: -1
    verbose: false
    gen_trt_engine:
    results_dir: null
    gpu_id: 0
    onnx_file: ???
    trt_engine: null
    input_channel: 3
    input_width: 960
    input_height: 544
    opset_version: 17
    batch_size: -1
    verbose: false
    tensorrt:
    data_type: FP32
    workspace_size: 1024
    min_batch_size: 4
    opt_batch_size: 4
    max_batch_size: 4
    calibration:
    cal_image_dir: ???
    cal_cache_file: ???
    cal_batch_size: 1
    cal_batches: 1
What’s the full error log?Could you please upload?
Also, please use the tao docker and run again. The command can be found in notebook.
This is the full error log. Using docker command it is working.
No log here. Could you upload again?
Glad to know it is working. Usually, you can use the tao docker to run. If you need to modify code, you can modify it(under /usr/…) inside the docker, and then run docker commit to save to a new docker.
