Configuration in preprocess
• Hardware Platform (Jetson / GPU) GPU
• DeepStream Version 6.2
• TensorRT Version 8.5.2-1+cuda11.8
• NVIDIA GPU Driver Version (valid for GPU only) 525.85.12
• Issue Type( questions, new requirements, bugs) questions
My custom pipeline includes prepocess for changing a input image size.
To reduce computation, i configured “network-mode” as FP16(2) from default FP32.
To match data format between preprocess and pgie, I also set “tensor-data-type” as FP16(5).
However, there was a system fault like below.
Custom Lib: Cuda Stream Synchronization failed
CustomTensorPreparation failed
ERROR: nvdsinfer_backend.cpp:506 Failed to enqueue trt inference batch
ERROR: nvdsinfer_context_impl.cpp:1720 Infer context enqueue buffer failed, nvinfer error:NVDSINFER_TENSORRT_ERROR
For your information, there was no error when I set “tensor-data-type” as FP32(0).
Can you explain why this error occurs?
Do you mean you configure the "network-mode” as FP16 with nvinfer and “tensor-data-type” as FP16 with nvdspreprocess?
What is your model’s input layer data type?
Do you mean you configure the "network-mode” as FP16 with nvinfer and “tensor-data-type” as FP16 with nvdspreprocess ?
Yes, you’re right.
My model’s input layer data type is FP32.
There was a ‘no’ error, when I set ‘FP32’ for data format for inference, at ‘preprocess’ configuration,
even though I used ‘FP16’ for data format to be used by inference, at ‘nvinfer’ configuration.
And there was an error, when I set ‘FP16’ for data format for inference, at ‘preprocess’ configuration,
“tensor-data-type” in nvdspreprocess should be aligned with your model’s input layers but has nothing to do with the model’s data type.
if input layer’s type is FP32, and ‘network-mode’ in nvinfer is FP16,
does nvinfer process type-casting(FP32 tensor to FP16 tensor) automatically?
The “network-mode” in nvinfer just build the TensorRT plan in FP16, it will not change the model’s input or output. Developer Guide :: NVIDIA Deep Learning TensorRT Documentation
My understanding is like below.
From nv12 format input buffer, system converts it for inference.
And this conversion is related to assigned value in network-mode in nvinfer.
Additionally, this process has no relationship with tensor-data-type in preprocess configuration.
Is it correct understanding?
No. The “network-mode” in nvinfer is just a TensoRT parameter to build the TensorRT plan.
No. There is no relationship between tensor-data-type and the TensorRT plan data type. tensor-data-type is the data type of the model’s input layer.
Please study TensorRT first before you try to understand the gst-nvinfer source code.
