Configuration Jetbot SD Card Image
Hi everyone, I need help with the configuration of my jetbot. I installed the version 4.6.1 in SD Card of Jetson Nano Developer Kit SD Card Image but this contain an user by default (user: jetson) and the password is unknown
Please use the SD card image in
Using SD Card Image - JetBot
And follow the steps.
I have already discovered why the configurations I have made with the SD have not worked. If I remove the SD card with the image, the start screen that I mentioned still loads. Apparently there is a configuration in the internal memory. How can I remove this configuration or have the device boot as a priority from the SD and not the internal configuration that is preventing me from using this device normally since I do not know the credentials?
It looks like you are using custom board from 3rdparty. Please check
Guidance to tell if you are using a NV developer kit
And please check with the vendor for the pre-created user and password.
Ok, I’m confused, I’m sharing images of the device I have, which I think is a jetson nano nvidia (JetBot)? How can I access the SD with the image with the JetPack with this device? As I explained to you, even if there is no SD inserted in the slot, it starts an Ubuntu OS already created with a user whose credentials I don’t know. Which prevents me from being able to advance in my thesis.
Please, Help Me!
