I have a dual port ConnectX-3 installed in a Dell R620 server running the following
- Centos 6.6
- mlnx driver 2.4.1.0.0.1
- Virtualbox 4.3.28
- Guest OS also Centos 6.6
- Bridged network adapter pointing to p1p1
Everything looks good when the VM boots up, I am able to ping remote machines over the 10G interface from the virtual machine and the host OS.
Problem occurs when I try to use the interface for anything more than ping, for example ssh to a machine on the 10G network.
This causes an error on the host OS, no error seen on the Guest OS.
Jun 19 13:25:29 localhost kernel: WARNING: at net/core/dev.c:1921 skb_warn_bad_offload+0x99/0xb0() (Tainted: P W --------------- )
Jun 19 13:25:29 localhost kernel: Hardware name: PowerEdge R620
Jun 19 13:25:29 localhost kernel: mlx4_core: caps=(0x3011cbb3, 0x0) len=73 data_len=0 ip_summed=1
Jun 19 13:25:29 localhost kernel: Modules linked in: bridge fuse nfsd exportfs autofs4 coretemp nfs lockd fscache auth_rpcgss nfs_acl sunrpc tun bnx2fc cnic uio fcoe libfcoe libfc scsi_transport_fc scsi_tgt vboxpci(U) vboxnetadp(U) vboxnetflt(U) vboxdrv(U) 8021q garp stp llc nf_conntrack_netbios_ns nf_conntrack_broadcast nf_conntrack_tftp nf_conntrack_ftp ip6t_REJECT nf_conntrack_ipv6 nf_defrag_ipv6 xt_state nf_conntrack ip6table_filter ip6_tables ipv6 uinput microcode iTCO_wdt iTCO_vendor_support dcdbas nvidia(P)(U) i2c_core power_meter acpi_ipmi ipmi_si ipmi_msghandler sb_edac edac_core ses enclosure sg lpc_ich mfd_core shpchp mlx4_ib(U) mlx4_en(U) mlx4_core(U) compat(U) tg3 ptp pps_core sr_mod cdrom ext4 jbd2 mbcache usb_storage sd_mod crc_t10dif ahci wmi megaraid_sas dm_mirror dm_region_hash dm_log dm_mod [last unloaded: speedstep_lib]
Jun 19 13:25:29 localhost kernel: Pid: 43322, comm: lspci Tainted: P W --------------- 2.6.32-504.23.4.el6.x86_64 #1
Jun 19 13:25:29 localhost kernel: Call Trace:
Jun 19 13:25:29 localhost kernel: [] ? warn_slowpath_common+0x87/0xc0
Jun 19 13:25:29 localhost kernel: [] ? warn_slowpath_fmt+0x46/0x50
Jun 19 13:25:29 localhost kernel: [] ? __ratelimit+0xd5/0x120
Jun 19 13:25:29 localhost kernel: [] ? skb_warn_bad_offload+0x99/0xb0
Jun 19 13:25:29 localhost kernel: [] ? copy_skb_header+0x17/0xa0
Jun 19 13:25:29 localhost kernel: [] ? __skb_gso_segment+0x71/0xc0
Jun 19 13:25:29 localhost kernel: [] ? skb_gso_segment+0x13/0x20
Jun 19 13:25:29 localhost kernel: [] ? vboxNetFltLinuxPacketHandler+0x352/0x620 [vboxnetflt]
Jun 19 13:25:29 localhost kernel: [] ? cpumask_next_and+0x29/0x50
Jun 19 13:25:29 localhost kernel: [] ? read_tsc+0x9/0x20
Jun 19 13:25:29 localhost kernel: [] ? getnstimeofday+0x57/0xe0
Jun 19 13:25:29 localhost kernel: [] ? __netif_receive_skb+0x4b9/0x570
Jun 19 13:25:29 localhost kernel: [] ? netif_receive_skb+0x58/0x60
Jun 19 13:25:29 localhost kernel: [] ? lro_flush+0x1a8/0x1b0
Jun 19 13:25:29 localhost kernel: [] ? lro_flush_all+0x54/0x70
Jun 19 13:25:29 localhost kernel: [] ? mlx4_en_process_rx_cq+0xc8a/0xea0 [mlx4_en]
Jun 19 13:25:29 localhost kernel: [] ? mlx4_en_rx_irq+0x54/0x60 [mlx4_en]
Jun 19 13:25:29 localhost kernel: [] ? mlx4_en_poll_rx_cq+0xa1/0x180 [mlx4_en]
Jun 19 13:25:29 localhost kernel: [] ? net_rx_action+0x103/0x2f0
Jun 19 13:25:29 localhost kernel: [] ? __do_softirq+0xc1/0x1e0
Jun 19 13:25:29 localhost kernel: [] ? handle_IRQ_event+0x60/0x170
Jun 19 13:25:29 localhost kernel: [] ? __do_softirq+0x11f/0x1e0
Jun 19 13:25:29 localhost kernel: [] ? call_softirq+0x1c/0x30
Jun 19 13:25:29 localhost kernel: [] ? do_softirq+0x65/0xa0
Jun 19 13:25:29 localhost kernel: [] ? irq_exit+0x85/0x90
Jun 19 13:25:29 localhost kernel: [] ? do_IRQ+0x75/0xf0
Jun 19 13:25:29 localhost kernel: [] ? ret_from_intr+0x0/0x11
Jun 19 13:25:29 localhost kernel: [] ? pci_user_read_config_word+0x93/0xc0
Jun 19 13:25:29 localhost kernel: [] ? pci_user_read_config_word+0x7d/0xc0
Jun 19 13:25:29 localhost kernel: [] ? pci_vpd_pci22_wait+0x52/0x110
Jun 19 13:25:29 localhost kernel: [] ? pci_vpd_pci22_read+0xe3/0x180
Jun 19 13:25:29 localhost kernel: [] ? pci_read_vpd+0x2b/0x30
Jun 19 13:25:29 localhost kernel: [] ? read_vpd_attr+0x30/0x40
Jun 19 13:25:29 localhost kernel: [] ? read+0x127/0x210
Jun 19 13:25:29 localhost kernel: [] ? vfs_read+0xb5/0x1a0
Jun 19 13:25:29 localhost kernel: [] ? sys_pread64+0x82/0xa0
Jun 19 13:25:29 localhost kernel: [] ? system_call_fastpath+0x16/0x1b
Jun 19 13:25:29 localhost kernel: —[ end trace bb7fb3c39b1f3d2c ]—
Is there a configuration setting that needs to be set?
