Hello, I recently received x2 Onyx 2410M switches for a project I am working on. I am a bit confused on how to define a route for the MGMT0 interface only. Specifically I want a default route for my general vlan interfaces then have the MGMT0 interface use a separate default route that goes into my OOBM network.
This page references the command “ip default-gateway” when int he MGMT0 configuration mode. That command is not present.
https://docs.mellanox.com/display/ONYXv381118/Management%20Interface%20Commands
Can someone please explain how MGMT0 default route works?
Hi Kevin,
If the default route on the mgmt0 interface is currently set to a next hop that is being provided by DHCP, the solution would be to disable DHCP on the mgmt0 interface, configure a static IP on the mgmt0 interface, and then configure a new static route with the next-hop IP for mgmt0. You can then use the ip default-gateway command for the default route going out your vlan interface:
no interface mgmt0 DHCP
interface mgmt0 ip address 192.168.10.10
ip default-gateway 0.0.0.0 0.0.0.0 10.130.55.10
ip route 192.168.0.0 255.255.0.0 mgmt0
After making the above changes, the route table should display entries similar to the following:
[mlag-vip-domain: master] (config) # show ip route
Flags:
F: Failed to install in H/W
B: BFD protected (static route)
i: BFD session initializing (static route)
x: protecting BFD session failed (static route)
c: consistent hashing
p: partial programming in H/W
VRF Name default:
192.168.0.0 255.255.255.0 0.0.0.0 mgmt0 direct 0/0
default 0.0.0.0 10.130.55.10 vlan55 static 1/1
Thanks/regards,
Kevin
