Hi ,
In Jetson TX2, I could configure ALSA default audio device for SND_PCM_ACCESS_RW_INTERLEAVED, SND_PCM_STREAM_PLAYBACK mode and audio playback works fine.
But When I try to configure ALSA default audio device for SND_PCM_ACCESS_RW_NONINTERLEAVED, SND_PCM_STREAM_PLAYBACK mode then below error is observed.
(snd_pcm_set_params) Access type not available for PLAYBACK: Invalid argument
Can someone please provide more details , How Jetson TX2’s ALSA to be configured for SND_PCM_ACCESS_RW_NONINTERLEAVED audio buffer playback use case?
Thanks And Regards,
Prabhakaran.
