Hello!
I’m trying to configure my Dell XPS 15-9500 on KDE Neon 20.04 (wayland) for use with an RTX 3060 in a PRIME configuration. The laptop has integrated graphics and a discrete GTX 1650. Originally, I had the 1650 usable for PRIME render offload (via prime-select on-demand
), and CUDA works on the RTX 3060 eGPU out of the box.
However, I would like to use the 3060 instead of the 1650 for PRIME. Is what I’m trying to do possible? I added the following in a new file under /usr/share/X11/xorg.conf.d
Section "Device"
Identifier "nvidiaegpu"
Driver "nvidia"
BusID "PCI:08:00:0" # Edit according to lspci, translate from hex to decimal.
Option "AllowExternalGpus" "True" # Required for proprietary NVIDIA driver.
EndSection
Section "Screen"
Device "nvidiaegpu"
EndSection
From nvidia-smi, I can see that Xorg is running on both GPUs. However, trying to run OpenGL or Vulkan applications with the appropriate environment variable flags only runs on the 1650. As far as I’m aware, there’s no BIOS option to disable the 1650. Is there some other configuration, Xorg or otherwise, I need to do this?
nvidia-bug-report.log.gz (513.8 KB)
