I was working on Jetson TX2 NX. In my target board, I am not using HDMI/display. So I am trying to configure DP0_HPD, HDMI_CEC, and DP1_HPD pins as GPIO pins. But I am not able to make them GPIO.
I edited the pin muxing table and generate dtsi file and flashed the board again.
when checking the state and direction in /sys/class/gpio/, it only shows ‘IN’ as direction and ‘0’ as state, even if it is set as output.
Please help me to make DP0_HPD, HDMI_CEC, and DP1_HPD pins as GPIO pins.
please refer to developer guide, pinmux changes. you should execute pinmux-dts2cfg.py to convert those *.dtsi files as new cfg file for image flashing.
please also check # cat /sys/kernel/debug/gpio for the GPIO configurations,
thanks
