I am evaluating connectX-7 MCX755106AS-HEAT on an HHHL Adapter Card (with standard PCIe edge connector). The card is connected to a PCIe switch that is capable of bifurcating 1x16 or 4x4. The CX7 works normally using 1x16 PCIe bifurcation while connected to a single host.
My goal is to connect 4 hosts using 4 different partitions within the PCIe switch and a 4x4 bifurcation to the CX7 to make it appear as 4 separate downstream ports. The CX7 works normally if I use the 4x4 bifurcation with a single host, the host sees the cx7 as one x4 device. In particular I can use mst* tools normally, which makes possible to configure or update the firmware.
What do I need to do to support additional hosts using the 3 others x4 ports?
