Hi, I’m currently following the Object Following tutorial (Tutorial for Obstacle Avoidance and Object Following Using cuMotion with Perception — isaac_ros_docs documentation). However, the robotic arm I’m using has fewer degrees of freedom, so it can’t achieve many of the target poses. I was wondering if there’s a way to configure the system to only consider the position the arm needs to reach, without enforcing any specific orientation.
Thanks in advance!
