Thanks a lot, I’ll look through it.
It seems as though there are two aspects when interfacing with the VI/ISP.
Device specific configuration: configurations that are camera/platform dependent. Like which CSI lanes a camera is attached to and the number of lanes.
Device independent configuration: configurations that are specific to a capture like the resolution of the image and where to route the images within the VI (ISP or Memory).
It looks like the DTSI is where camera/platform dependent settings should be configured and the camera/platform independent configurations is what libargus is for. Is this true?
Camera/Platform Dependent Configuration
Looking at the DTSI file for the E3326 camera expansion board
/arch/arm64/boot/dts/tegra210-platform/tegra210-camera-e3326-camera-a00.dtsi
which declares the configuration values for the OV5693 camera at a resolution of 2552 X 1944:
mode0 { // OV5693_MODE_2592X1944
mclk_khz = "24000";
num_lanes = "2";
tegra_sinterface = "serial_c";
discontinuous_clk = "no";
dpcm_enable = "false";
cil_settletime = "0";
active_w = "2592";
active_h = "1944";
pixel_t = "bayer_bggr";
readout_orientation = "180";
line_length = "2688";
inherent_gain = "1";
mclk_multiplier = "17.0";
pix_clk_hz = "160000000";
min_gain_val = "1.0";
max_gain_val = "16";
min_hdr_ratio = "1";
max_hdr_ratio = "64";
min_framerate = "1.816577";
max_framerate = "30";
min_exp_time = "34";
max_exp_time = "550385";
embedded_metadata_height = "0";
It looks like the ‘modes’ within the DTSI file correspond to the sensor settings within:
/drivers/media/i2c/ov5693_mode_tbls.h
Specifically the configuration values found here:
static const struct camera_common_frmfmt ov5693_frmfmt[] = {
{{2592, 1944}, ov5693_30fps, 1, 0, OV5693_MODE_2592X1944},
{{2592, 1458}, ov5693_30fps, 1, 0, OV5693_MODE_2592X1458},
{{1920, 1080}, ov5693_30fps, 1, 0, OV5693_MODE_1920X1080},
{{1280, 720}, ov5693_120fps, 1, 0, OV5693_MODE_1280X720_120FPS},
{{2592, 1944}, ov5693_24fps, 1, 1, OV5693_MODE_2592X1944_HDR},
{{1920, 1080}, ov5693_30fps, 1, 1, OV5693_MODE_1920X1080_HDR},
Where ‘mode0’ within the DTSI file is the ‘mode0’ within this structure. I know the mode table structure is used to configure the actual sensor over I2C and it seems as though the information in a DTSI mode is supposed to be used to configure the VI/ISP for a specific mode. Is this correct?
If the purpose of ‘modeX’ configuration is supposed to be used to configure the camera/platform dependent configurations within the VI/ISP where is it actually executed? If my understand is correct I can start configuring the ISP to read raw bayer data from my camera. I’ve grepped around the kernel and can’t find anywhere that attempts to read things like ‘mclk_khz’ from the dts. Is there a specific file, such as:
/arch/arm64/mach-tegra/board-t210ref-camera.c
or
/driver/media/i2c/CAMERA_NAME.c
Where the DTSI is read from and then used to configure the VI/ISP?
Thanks again for the feedback.
Dave
