Confirming TX2 auto-power-on behavior
I am working on a custom carrier board and want to confirm the behavior of auto-power-on:
  • Can you provide a schematic for the auto-power-on circuit that is on the TX2 module?
  • Can you provide the part number for the TX2’s PMIC?
  • What is the behavior of the auto-power-on circuit after a PMIC reset (RESET_IN# active)? Does the ACOK bit persist after a PMIC reset? If not, will ACOK be pulled low 300 ms after the PMIC reset or will the TX2 have to be fully power cycled (VDD_IN removed)?
hello ck240,
you may refer to Jetson TX2 Series OEM Product Design Guide for the power circuit.
there’s also a session for power-on control you may check for more details.
thanks
Hi Jerry,
The OEM product design does not clearly answer the questions in my original post. If you are able to, providing a schematic for the auto-power-on circuit and the part number for the PMIC would help me find the information I need.
The module schematic is not public. PMIC part number is MAX77620. ACOK is always tied to ground on carrier board for auto-power-on.
Thank you for confirming the PMIC part number.
I am still wondering about the auto-power-on-circuit behavior during two events:
  1. Assume CHARGER_PRSNT is tied to ground on the carrier board. RESET_IN is then activated some time after initial boot, resetting the PMIC. VDD_IN remains connected. Will the TX2 auto-power-on after the reset?
  2. Assume CHARGER_PRSNT is tied to ground on the carrier board. VDD_IN browns out some time after initial boot, resulting in VIN_PWR_BAD becoming active. The PMIC shuts down. Once VIN_PWR_BAD is no longer active, will the TX2 auto-power-on?
  1. RESET process is not auto-power-on, whole system will reset (restart) with RESET_IN asserted.
  2. It also depends on the action of VDD_IN. If VDD_IN is stable and vin_pwr_bad is asserted and then de-asserted, the auto-power-on will be triggered.
