This issue is also related to the articles mentioned above. When the Collision Geometry is set to SDF, it is necessary to enable GPU dynamics. However, effort control is required to grasp objects, but the joint_efforts
in the ArticulationAction
class passed to apply_action
is only supported on the CPU and cannot be used. How can this be resolved?
Related topics
Topic | Replies | Views | Activity | |
Regarding set_joint_efforts | 0 | 188 | June 14, 2024 | |
Issue with GPU pipeline | 2 | 186 | September 17, 2024 | |
About isaac sim 2023.1.1 crash bug on robotic arm,Invalid for collision grabbing | 6 | 235 | July 11, 2024 | |
Interpenetration of objects and incoherent force measurement with physx engine | 3 | 1877 | January 20, 2023 | |
Does Isaac SIM currently only support SDF mesh running on GPUs? | 2 | 56 | September 25, 2024 | |
I want to detect the collision between the gripper and the building blocks using SDF Mesh, but in the isaac sim simulation interface, no collision | 2 | 57 | August 14, 2024 | |
Suction Gripper API Documentation | 5 | 583 | October 27, 2023 | |
How to Add a Surface Gripper Joint to an Articulation in Isaac Sim? | 0 | 38 | January 27, 2025 | |
Challenges with Robotiq 3F Gripper in Isaac Sim: Object Slippage and Clipping | 5 | 322 | June 28, 2024 | |
Isaac Sim gripper going through object | 2 | 346 | July 22, 2024 |
