Hello all,
I am checking my code by enabling the CUDA Memory Checker in Nsight Visual Studio and then running the CUDA debugger. This yields no error messages and my simulation outputs for a number of test cases all look correct. However, when running the same test cases using compute-sanitizer
, many errors are reported. Which of the two should I trust? My issue is that if I try to inspect the offending thread indices using the CUDA Debugger as flagged by compute-sanitizer
, no problems show up, and the results appear to be correct as well.
Information:
GTX 1050 Notebook
CUDA 11.2
Driver 461.40
Nsight Build 2020.3.0.20315
Cheers.
