Hello all, we have a number of Nano’s and are unsure what SD image to use for them. For example, the JetPack SDK has images for Xavier NX and Orin. I am a newbie to the models. On the PCB of our Nano’s it has “Model P3450”. Which image? From searching there are also Tx1’s and TX2’s I believe as well. My apologies for such a newbie question…I inherited this project.
The images I spoke of are at JetPack SDK | NVIDIA Developer, but learning the model terminology I am sure is essential when we move to our next steps. Thank all of you who help here. :)
JetPack/SDK Manager is a GUI front end to the software which actually gets flashed. The flashed content is “Linux for Tegra” (“L4T”), which in turn is just Ubuntu plus NVIDIA drivers. You can find a list of L4T releases here, which has links to the JetPack/SDKM which flashes those releases: https://developer.nvidia.com/embedded/jetson-linux-archive
Typically, if you were to flash on command line, then it would go something like this (which is basically what the GUI does under the covers from the “Linux_for_Tegra/” directory of the flash software): sudo ./flash.sh jetson-nano mmcblk0p1
In the above the “target” is “jetson-nano”, which tells the flash software to use “jetson-nano.conf”. In that same location you could see all of the conf files with “ls *.conf”. Any of those which describes your particular Jetson would be a target, less the “.conf” suffix.
Note that if you look at those same conf files with “ls -l *.conf”, then you’ll see many are symbolic links, which are just aliases for other file names. Overall any Jetson is a combination of the module model itself, plus the carrier board. One designation is for the module, the other for the carrier board (p3450 is one example, but there might be a series of compatible modules or carrier boards). Note that all of the “common name” aliases point at one of the more obscure “p####” conf files. Just use the name which matches the human-readable name of your Jetson.
Very much appreciate your reply! You clarified my understanding of the terminology that I was just missing in the documentation!
I am still confused on the exact version of Nano I have but will work through it. The v5.x of Jetpack did not work on the Nano’s we have but a previous version did. That is what led to this post.
Someone from NVIDIA could tell you something about the specific model from “p3450”, but the above tells me this is likely just a dev kit. I don’t know if p3450 is for carrier board or module. Any QSPI is a reference to the boot memory which an SD card model uses (not a secondary SD card, but one used in boot).
Yes it is a DevKit. We have production nanos on sites but these kits are used in our dev department. The P3450 is the carrier board…the board with the USB ports on it. I am learning! lol
One thing I just noticed and forgot to mention earlier: No JetPack 5.x will work with a Nano. You’d have to stick with 4.x. The p3450 says this is a dev kit Nano, and Nanos do not receive new feature updates (which is what the JetPack 5.x is).
