When I studied the connection mode between Jatson and de-Serializer, I encountered the following problems:
Section 3.3 on page 19 of dG-09364-001_v1.3 describes Mapping #2 in “Xavier to Serializer C-PHY Signal Mapping” support both C-PHY and D-PHY,If only c-PHY connection is required, use either Mapping #1 or Mapping #2 connection.
But The Note below“Figure 3-3. Signal Routing Using Default Xavier Mapping” indicates that this connection mode supports D-PHY and C-PHY, but “the Figure 3-3” shows that it is Map1 in “ Table 3-2. Xavier to Serializer C-PHY Signal Mapping” which means the connection mode should only support C-PHY.
Note below“Figure 3-4. Signal Routing with Xavier C-PHY Swizzle Mapping” indicates that this connection mode only supports C-PHY, But “the Figure 3-4” shows that it is Map2 in “ Table 3-2. Xavier to Serializer C-PHY Signal Mapping” which means the connection mode should only support C-PHY and D-PHY
I’m a little confused here, which description is true?
