When I run inference on video for object detection I see the output as in image. At the first time we have a pattern:
PERF: FPS 0 (avg)
And then we have a pattern such as
PERF: 35.12 (35.09)
It means that our FPS ~ 35. It is right?
Please correct me if i am wrong. Thank you.
Yes, the fps for your pipeline is 35fps.
The fps is calculated dynamically.
When the pipeline starts, some initialization is required.
That’s why the fps is 0 (wait for the initialization) at the beginning.
Thank you. I got it. Values in brackets and outside brackets are current FPS and average FPS for specific interval respectively. Is it right?
system
Closed
June 7, 2023, 6:12am
8
