Hi all,
i had an issue recently with a port on the switch but in the logs it tells me
Action ID 10784: param: interface ifindex: “117”
yet there seems to be no way to find the ifindex number tied to the ports on switch
thanks
Mat
Hi all,
thanks
Mat
Hi, it traces back to this snmp table:
snmptable -v 2c -c public 10.240.10.52 1.3.6.1.2.1.2.2 | awk ‘{print $1" " $2}’
Depending on the switch software version the mapping may be different.
Table output is like this:
ifIndex ifDescr
1 lo
2 mgmt0
3 mgmt1
4 ib0
65 /SX/9
67 /SX/12
69 /SX/11
70 /SX/14
72 /SX/13
74 /SX/16
etc…
Whereas: /SX/number means the ib port 1/number
Usually though, any log entry referencing an interface index number has surrounding log messages with the same timestamp that reference the associated port number. For example:
Nov 20 02:03:28 sw123 cli[27777]: [cli.NOTICE]: user admin: Executing command: interface ethernet 1/1 clear counters
Nov 20 02:03:28 sw123 mgmtd[2024]: [mgmtd.NOTICE]: Action ID 614: requested by: user admin (System Administrator) via CLI
Nov 20 02:03:28 sw123 mgmtd[2024]: [mgmtd.NOTICE]: Action ID 614: descr: Clears the port counters
Nov 20 02:03:28 sw123 mgmtd[2024]: [mgmtd.NOTICE]: Action ID 614: status: completed with success
Nov 20 02:03:28 sw123 mgmtd[2024]: [mgmtd.NOTICE]: Action ID 615: param: interface ifindex: “114”
********Here ifindex 114 mayches port 1
Another example:
Jan 11 01:57:11 sn2700-2 ifd[4029]: TID 140295984342848: [ifd.NOTICE]: handling vlan oper state change, vlan: 4001, ifindex: 55001, state: up
Jan 11 01:57:11 sn2700-2 ufma[3687]: TID 140065668282112: [ufma.NOTICE]: Received event: /net/interface/events/link_up
Jan 11 01:57:11 sn2700-2 mlagd[4042]: TID 140035449181952: [mlagd.NOTICE]: got event ‘/iss/events/mlag_or_ipl_state_change’
Jan 11 01:57:11 sn2700-2 mlagd[4042]: TID 140035449181952: [mlagd.NOTICE]: processing op ipl1 oper U
Jan 11 01:57:11 sn2700-2 mlagd[4042]: TID 140035449181952: [mlagd.NOTICE]: ipl1 Po16 changed its oper state to up
*******Above shows that ifindex 55001 is P016 (port channel 16)
