Conjugate Gradient With Preconditioner Sample
I took the CG with-preconditioner sample and used the genTridiag() data from the without-preconditioner sample so that I could compare directly the two methods.
However, I find that using the genTridiag() data the sample hangs.
I simply moved the code into a function called solveBothMethods() and call this from main().
I also changed the size of nzILU0 to the number of non-zeroes:
//int nzILU0 = 2*N-1;
int nzILU0 = nz;
/* Solve Ax=b using the conjugate gradient method a) without any preconditioning, b) using an Incomplete Cholesky preconditioner and c) using an ILU0 preconditioner. */
int solveBothMethods(int argc, char **argv)
const int max_iter = 1000;
int k, M = 0, N = 0, nz = 0, *I = NULL, *J = NULL;
int *d_col, *d_row;
int qatest = 0;
const float tol = 1e-12f;
float *x, *rhs;
float r0, r1, alpha, beta;
float *d_val, *d_x;
float *d_zm1, *d_zm2, *d_rm2;
float *d_r, *d_p, *d_omega, *d_y;
float *val = NULL;
float *d_valsILU0;
float *valsILU0;
float rsum, diff, err = 0.0;
float qaerr1, qaerr2 = 0.0;
float dot, numerator, denominator, nalpha;
const float floatone = 1.0;
const float floatzero = 0.0;
int nErrors = 0;
printf("conjugateGradientPrecond starting...\n");
/* QA testing mode */
if (checkCmdLineFlag(argc, (const char **)argv, "qatest"))
    qatest = 1;
/* This will pick the best possible CUDA capable device */
cudaDeviceProp deviceProp;
int devID = findCudaDevice(argc, (const char **)argv);
printf("GPU selected Device ID = %d \n", devID);
if (devID < 0)
    printf("Invalid GPU device %d selected,  exiting...\n", devID);
    exit(EXIT_SUCCESS);
checkCudaErrors(cudaGetDeviceProperties(&deviceProp, devID));
/* Statistics about the GPU device */
printf("> GPU device has %d Multi-Processors, SM %d.%d compute capabilities\n\n",
       deviceProp.multiProcessorCount, deviceProp.major, deviceProp.minor);
int version = (deviceProp.major * 0x10 + deviceProp.minor);
if (version < 0x11)
    printf("%s: requires a minimum CUDA compute 1.1 capability\n", sSDKname);
    cudaDeviceReset();
    exit(EXIT_SUCCESS);
/* Generate a random tridiagonal symmetric matrix in CSR (Compressed Sparse Row) format */
M = N = 16384;
nz = 5*N-4*(int)sqrt((double)N);
I = (int *)malloc(sizeof(int)*(N+1));                              // csr row pointers for matrix A
J = (int *)malloc(sizeof(int)*nz);                                 // csr column indices for matrix A
val = (float *)malloc(sizeof(float)*nz);                           // csr values for matrix A
x = (float *)malloc(sizeof(float)*N);
rhs = (float *)malloc(sizeof(float)*N);
for (int i = 0; i < N; i++)
    rhs[i] = 0.0;                                                  // Initialize RHS
    x[i] = 0.0;                                                    // Initial approximation of solution
genLaplace(I, J, val, M, N, nz, rhs);
M = N = 1048576;
nz = (N-2)*3 + 4;
    rhs[i] = 1.0;
    x[i] = 0.0;
genTridiag(I, J, val, N, nz);
// start timer after built and filled tri-diag matrix
clock_t startTime = clock();
/* Create CUBLAS context */
cublasHandle_t cublasHandle = 0;
cublasStatus_t cublasStatus;
cublasStatus = cublasCreate(&cublasHandle);
checkCudaErrors(cublasStatus);
/* Create CUSPARSE context */
cusparseHandle_t cusparseHandle = 0;
cusparseStatus_t cusparseStatus;
cusparseStatus = cusparseCreate(&cusparseHandle);
checkCudaErrors(cusparseStatus);
/* Description of the A matrix*/
cusparseMatDescr_t descr = 0;
cusparseStatus = cusparseCreateMatDescr(&descr);
/* Define the properties of the matrix */
cusparseSetMatType(descr,CUSPARSE_MATRIX_TYPE_GENERAL);
cusparseSetMatIndexBase(descr,CUSPARSE_INDEX_BASE_ZERO);
/* Allocate required memory */
checkCudaErrors(cudaMalloc((void **)&d_col, nz*sizeof(int)));
checkCudaErrors(cudaMalloc((void **)&d_row, (N+1)*sizeof(int)));
checkCudaErrors(cudaMalloc((void **)&d_val, nz*sizeof(float)));
checkCudaErrors(cudaMalloc((void **)&d_x, N*sizeof(float)));
checkCudaErrors(cudaMalloc((void **)&d_y, N*sizeof(float)));
checkCudaErrors(cudaMalloc((void **)&d_r, N*sizeof(float)));
checkCudaErrors(cudaMalloc((void **)&d_p, N*sizeof(float)));
checkCudaErrors(cudaMalloc((void **)&d_omega, N*sizeof(float)));
cudaMemcpy(d_col, J, nz*sizeof(int), cudaMemcpyHostToDevice);
cudaMemcpy(d_row, I, (N+1)*sizeof(int), cudaMemcpyHostToDevice);
cudaMemcpy(d_val, val, nz*sizeof(float), cudaMemcpyHostToDevice);
cudaMemcpy(d_x, x, N*sizeof(float), cudaMemcpyHostToDevice);
cudaMemcpy(d_r, rhs, N*sizeof(float), cudaMemcpyHostToDevice);
/* Conjugate gradient without preconditioning.
   Follows the description by Golub & Van Loan, "Matrix Computations 3rd ed.", Section 10.2.6  */
printf("Convergence of conjugate gradient without preconditioning: \n");
k = 0;
r0 = 0;
cublasSdot(cublasHandle, N, d_r, 1, d_r, 1, &r1);
while (r1 > tol*tol && k <= max_iter)
    k++;
    if (k == 1)
        cublasScopy(cublasHandle, N, d_r, 1, d_p, 1);
    else
        beta = r1/r0;
        cublasSscal(cublasHandle, N, &beta, d_p, 1);
        cublasSaxpy(cublasHandle, N, &floatone, d_r, 1, d_p, 1) ;
    cusparseScsrmv(cusparseHandle,CUSPARSE_OPERATION_NON_TRANSPOSE, N, N, nz, &floatone, descr, d_val, d_row, d_col, d_p, &floatzero, d_omega);
    cublasSdot(cublasHandle, N, d_p, 1, d_omega, 1, &dot);
    alpha = r1/dot;
    cublasSaxpy(cublasHandle, N, &alpha, d_p, 1, d_x, 1);
    nalpha = -alpha;
    cublasSaxpy(cublasHandle, N, &nalpha, d_omega, 1, d_r, 1);
    r0 = r1;
printf("  iteration = %3d, residual = %e \n", k, sqrt(r1));
cudaMemcpy(x, d_x, N*sizeof(float), cudaMemcpyDeviceToHost);
double duration = double( clock() - startTime ) / (double)CLOCKS_PER_SEC;
std::cout << "time to solve non-preconditioned system: " << duration << std::endl;
/* check result */
err = 0.0;
    rsum = 0.0;
    for (int j = I[i]; j < I[i+1]; j++)
        rsum += val[j]*x[J[j]];
    diff = fabs(rsum - rhs[i]);
    if (diff > err)
        err = diff;
printf("  Convergence Test: %s \n", (k <= max_iter) ? "OK" : "FAIL");
nErrors += (k > max_iter) ? 1 : 0;
qaerr1 = err;
if (0)
    // output result in matlab-style array
    int n=(int)sqrt((double)N);
    printf("a = [  ");
    for (int iy=0; iy<n; iy++)
        for (int ix=0; ix<n; ix++)
            printf(" %f ", x[iy*n+ix]);
        if (iy == n-1)
            printf(" ]");
        printf("\n");
/* Preconditioned Conjugate Gradient using ILU.
   Follows the description by Golub & Van Loan, "Matrix Computations 3rd ed.", Algorithm 10.3.1  */
printf("\nConvergence of conjugate gradient using incomplete LU preconditioning: \n");
int nzILU0 = nz;
valsILU0 = (float *) malloc(nz*sizeof(float));
checkCudaErrors(cudaMalloc((void **)&d_valsILU0, nz*sizeof(float)));
checkCudaErrors(cudaMalloc((void **)&d_zm1, (N)*sizeof(float)));
checkCudaErrors(cudaMalloc((void **)&d_zm2, (N)*sizeof(float)));
checkCudaErrors(cudaMalloc((void **)&d_rm2, (N)*sizeof(float)));
/* create the analysis info object for the A matrix */
cusparseSolveAnalysisInfo_t infoA = 0;
cusparseStatus = cusparseCreateSolveAnalysisInfo(&infoA);
/* Perform the analysis for the Non-Transpose case */
cusparseStatus = cusparseScsrsv_analysis(cusparseHandle, CUSPARSE_OPERATION_NON_TRANSPOSE,
                                         N, nz, descr, d_val, d_row, d_col, infoA);
/* Copy A data to ILU0 vals as input*/
cudaMemcpy(d_valsILU0, d_val, nz*sizeof(float), cudaMemcpyDeviceToDevice);
/* generate the Incomplete LU factor H for the matrix A using cudsparseScsrilu0 */
cusparseStatus = cusparseScsrilu0(cusparseHandle, CUSPARSE_OPERATION_NON_TRANSPOSE, N, descr, d_valsILU0, d_row, d_col, infoA);
/* Create info objects for the ILU0 preconditioner */
cusparseSolveAnalysisInfo_t info_u;
cusparseCreateSolveAnalysisInfo(&info_u);
cusparseMatDescr_t descrL = 0;
cusparseStatus = cusparseCreateMatDescr(&descrL);
cusparseSetMatType(descrL,CUSPARSE_MATRIX_TYPE_GENERAL);
cusparseSetMatIndexBase(descrL,CUSPARSE_INDEX_BASE_ZERO);
cusparseSetMatFillMode(descrL, CUSPARSE_FILL_MODE_LOWER);
cusparseSetMatDiagType(descrL, CUSPARSE_DIAG_TYPE_UNIT);
cusparseMatDescr_t descrU = 0;
cusparseStatus = cusparseCreateMatDescr(&descrU);
cusparseSetMatType(descrU,CUSPARSE_MATRIX_TYPE_GENERAL);
cusparseSetMatIndexBase(descrU,CUSPARSE_INDEX_BASE_ZERO);
cusparseSetMatFillMode(descrU, CUSPARSE_FILL_MODE_UPPER);
cusparseSetMatDiagType(descrU, CUSPARSE_DIAG_TYPE_NON_UNIT);
cusparseStatus = cusparseScsrsv_analysis(cusparseHandle, CUSPARSE_OPERATION_NON_TRANSPOSE, N, nz, descrU, d_val, d_row, d_col, info_u);
/* reset the initial guess of the solution to zero */
    x[i] = 0.0;
checkCudaErrors(cudaMemcpy(d_r, rhs, N*sizeof(float), cudaMemcpyHostToDevice));
checkCudaErrors(cudaMemcpy(d_x, x, N*sizeof(float), cudaMemcpyHostToDevice));
k = 0;
    // Forward Solve, we can re-use infoA since the sparsity pattern of A matches that of L
    cusparseStatus = cusparseScsrsv_solve(cusparseHandle, CUSPARSE_OPERATION_NON_TRANSPOSE, N, &floatone, descrL,
                                          d_valsILU0, d_row, d_col, infoA, d_r, d_y);
    // Back Substitution
    cusparseStatus = cusparseScsrsv_solve(cusparseHandle, CUSPARSE_OPERATION_NON_TRANSPOSE, N, &floatone, descrU,
                                          d_valsILU0, d_row, d_col, info_u, d_y, d_zm1);
    k++;
    if (k == 1)
        cublasScopy(cublasHandle, N, d_zm1, 1, d_p, 1);
    else
        cublasSdot(cublasHandle, N, d_r, 1, d_zm1, 1, &numerator);
        cublasSdot(cublasHandle, N, d_rm2, 1, d_zm2, 1, &denominator);
        beta = numerator/denominator;
        cublasSaxpy(cublasHandle, N, &floatone, d_zm1, 1, d_p, 1) ;
    cusparseScsrmv(cusparseHandle,CUSPARSE_OPERATION_NON_TRANSPOSE, N, N, nzILU0, &floatone, descrU, d_val, d_row, d_col, d_p, &floatzero, d_omega);
    cublasSdot(cublasHandle, N, d_p, 1, d_omega, 1, &denominator);
    alpha = numerator / denominator;
    cublasScopy(cublasHandle, N, d_r, 1, d_rm2, 1);
    cublasScopy(cublasHandle, N, d_zm1, 1, d_zm2, 1);
    nalpha = -alpha;
std::cout << "time to solve preconditioned system: " << duration << std::endl;
/* check result */
err = 0.0;
    rsum = 0.0;
    if (diff > err)
        err = diff;
qaerr2 = err;
/* Destroy paramters */
cusparseDestroySolveAnalysisInfo(infoA);
cusparseDestroySolveAnalysisInfo(info_u);
/* Destroy contexts */
cusparseDestroy(cusparseHandle);
cublasDestroy(cublasHandle);
/* Free device memory */
free(I);
free(J);
free(val);
free(x);
free(rhs);
free(valsILU0);
cudaFree(d_col);
cudaFree(d_row);
cudaFree(d_val);
cudaFree(d_x);
cudaFree(d_y);
cudaFree(d_r);
cudaFree(d_p);
cudaFree(d_omega);
cudaFree(d_valsILU0);
cudaFree(d_zm1);
cudaFree(d_zm2);
cudaFree(d_rm2);
cudaDeviceReset();
printf("  Test Summary:\n");
printf("     Counted total of %d errors\n", nErrors);
printf("     qaerr1 = %f qaerr2 = %f\n\n", fabs(qaerr1), fabs(qaerr2));
//exit((nErrors == 0 &&fabs(qaerr1)<1e-5 && fabs(qaerr2) < 1e-5 ? EXIT_SUCCESS : EXIT_FAILURE));
int main(int argc, char **argv)
//solveWithPreconditioner(argc,argv);
solveBothMethods(argc,argv);
std::cout << "Paused, press ENTER to continue." << std::endl;
std::cin.get();
