Hi guys,
I’m trying to configure a network of 3 nodes to comunicate over IB without using a switch.
Each node is equiped with a dual-port ConnectX-4 adapter, so I thought it might be possible to connect them directly with each other.
So this is basically the setup I thought about:
Node1----------Node2----------Node3
The other possible solution would be to setup a ring, so that every node has a direct connection to every other node:
The problem is i coudn’t figure out the correct way to set this up.
What is the correct configuration for the subnetmanager in this setup?
I hope you can help me.
Hi Benedikt,
Have you tried to run opesnm -B in a triangle connection?
Does the opensm starts? (sminfo)
Regards,
Sophie.
Hi Sophie,
thanks for your reply.
I can start them in a ring, but then I still got 3 different subnetworks.
Is there a way to connect them to one network?
Edit:
I tried setting it up as a triangle setup, but the HCA1 always suppresses the HCA2 Interface.
I always get only the hosts and the subnetmanager from the first Port wit ibhosts or sminfo.
Regards,
Benedikt
Hi Benedikt,
Unfortunately, without a switch, this is the expected behavior and can not be changed.
Only through switch(s) the SM can discover all ports and place them under the same subnet.
Regards,
Sophie.
