Can I just check a couple of things
Is there any issues using Connect-4 LX with the follow items/configuration
MMA2L20-AR GBICs
With Windows Server 2016
With a DAC in one port and an MMA2L20-AR in the other
Many Thanks
MMA2L20-AR GBICs
Many Thanks
The answer is Yes - Should be no problem using MMA2L20-AR optical transceiver (gbic) w/ConnectX-4 LX adapter. Mellanox supports it
The same goes for “duality” usage of DAC in one port & MMA2L20-AR in the other port
see: https://www.mellanox.com/related-docs/prod_cables/PB_MMA2L20-AR_25GbE_SFP28_LR_Transceiver.pdf
Hope this helps
