Good day,
I am having a bit of an issue getting a keyboard (or terminal session) connected to this unit in order to flash it manually …
Tried using USB 3.1 to connect to using my Windows 11 notebook - however, in device manager I am getting the following error: “
Unknown USB Device (Port Reset Failed)“ -
Also tried removing the USB hub and reinstalling the unknown device, using device manager… no luck …
So I can’t try the LAN option and putty into it - network stack not loaded… so its either a terminal session via USB or getting a keyboard working on the device using one of the 3x USB ports ….
So yes, pretty frustrating this with this little guy atm….
Thank you - any tips or tricks will be greatly appreciated…
