Connecting 4 Holoscan Sensor Bridge Boards via a 1 QSFP+ to 4 SFP+ Cable
We are considering connecting an IGX Orin to 4 Holoscan Sensor Bridge boards using a 1 QSFP+ to 4 SFP+ cable. We would like to know if this is feasible, and whether modifying the source code of the Holoscan Sensor Bridge to enumerate all the boards simultaneously would work.
Are there any limitations with the Holoscan Sensor Bridge IP that would prevent this setup from functioning as expected?
Cable like this one, 40G QSFP+ & Breakout DAC - 產品資訊 - 翔生科技有限公司,Jumbo-Sun Technology Co., Ltd.
Best regards,
David
We discussed connecting an IGX Orin to four Holoscan Sensor Bridge boards using a 1 QSFP+ to 4 SFP+ breakout cable internally. The key points are:
  1. This setup is not currently possible with the standard IGX configuration.
  2. The IGX uses a ConnectX-7 (CX7) network interface card (NIC) with two QSFP ports, each capable of supporting two MACs.
  3. By default, the IGX firmware only exposes two ports in Linux, not four.
  4. To use all four SFP+ connections, a special firmware build would be required to enable breakout mode on the CX7. This would require testing.
  5. Even with a custom firmware, the maximum configuration would likely be:
  • Using both QSFP ports
  • Each QSFP port split into two SFP+ ports
  • Resulting in 4x50G connections (or potentially 4x25G)
  1. Creating a custom firmware for this setup adds complexity and may not be recommended for customer use.
As an alternative consider that our system is a full-fledged ethernet networking solution, so you can use any switch that can do the aggregation for you.
Thank you for your detailed reply.
We will continue to explore the application value of Holoscan Sensor Bridge.
