I am currently trying to send small bits of data (such as a set of coordinates) from the Jetson to the sbRIO 9628 board. They are connected with a USB cable. One end is plugged into the device port of the sbRIO, the other is plugged into an adapter that plugs into the usb0 port of the Jetson. I am currently trying to establish the connection via USB Ethernet modules, but am having difficulty setting up the network interface over usb0. What drivers are involved with USB network devices on the Jetson? Is there an easier way to approach this?
Hello @nls123,
What other options do you have for connecting one board to the other ?
Do you happen to have the spec sheet for the sbRIO board so we can understand a bit better its capabilities and IO ?
regards,
Andrew
