After plugging in a RealSense camera, we observe the following output from the dmesg tool:
dmesg_output_after_plugging_in_usb_cam.log (106.2 KB)
Here’s the output in /var/log/syslog:
syslog_output_after_plugging_in_usb_cam.log (1.2 MB)
In addition, this is the output of journalctl -b -u nvargus-damon, which shows the messages from nvargus-daemon just after plugging in the camera (at timestamp 11:00):
journalctl_nvargus_daemon.log (30.8 KB)
Here are the messages from that:
Sep 07 10:56:48 sensor-xavier systemd[1]: Started Argus daemon.
Sep 07 10:57:15 sensor-xavier nvargus-daemon[6804]: === NVIDIA Libargus Camera Service (0.97.3)=== Listening for connections...=== person_detector_node[8875]: Connection established (7F76DF01D0)OFParserListModules: module list: /pr
Sep 07 10:57:15 sensor-xavier nvargus-daemon[6804]: OFParserListModules: module list: /proc/device-tree/tegra-camera-platform/modules/module1
Sep 07 10:57:15 sensor-xavier nvargus-daemon[6804]: OFParserListModules: module list: /proc/device-tree/tegra-camera-platform/modules/module2
Sep 07 10:57:15 sensor-xavier nvargus-daemon[6804]: OFParserListModules: module list: /proc/device-tree/tegra-camera-platform/modules/module3
Sep 07 10:57:15 sensor-xavier nvargus-daemon[6804]: NvPclHwGetModuleList: WARNING: Could not map module to ISP config string
Sep 07 10:57:15 sensor-xavier nvargus-daemon[6804]: NvPclHwGetModuleList: No module data found
Sep 07 10:57:15 sensor-xavier nvargus-daemon[6804]: OFParserGetVirtualDevice: virtual device driver node not found in proc device-tree: /proc/device-tree/tegra-virtual-camera-platform/modules/module0/drivernode1
Sep 07 10:57:15 sensor-xavier nvargus-daemon[6804]: OFParserGetVirtualDevice: virtual device driver node not found in proc device-tree: /proc/device-tree/tegra-virtual-camera-platform/modules/module1/drivernode0
Sep 07 10:57:15 sensor-xavier nvargus-daemon[6804]: ---- imager: Found override file [/var/nvidia/nvcam/settings/camera_overrides.isp]. ----
Sep 07 10:57:15 sensor-xavier nvargus-daemon[6804]: CAM: serial no file already exists, skips storing again---- imager: Found override file [/var/nvidia/nvcam/settings/camera_overrides.isp]. ----
Sep 07 11:00:35 sensor-xavier nvargus-daemon[6804]: CAM: serial no file already exists, skips storing again=== person_detector_node[8875]: CameraProvider initialized (0x7f70ab8550)CAM: serial no file already exists, skips storing a
Sep 07 11:00:35 sensor-xavier nvargus-daemon[6804]: initializeDevNode: Failed to open dev node '/dev/camera/video4'; No such file or directory, trying alternate default location
Sep 07 11:00:35 sensor-xavier nvargus-daemon[6804]: (NvCamV4l2) Error BadParameter: Control 10094858 not found (in /dvs/git/dirty/git-master_linux/camera/utils/nvcamv4l2/v4l2_device.cpp, function findControlById(), line 1874)
Sep 07 11:00:35 sensor-xavier nvargus-daemon[6804]: (NvCamV4l2) Error BadParameter: (propagating from /dvs/git/dirty/git-master_linux/camera/utils/nvcamv4l2/v4l2_device.cpp, function getControlRange(), line 331)
Sep 07 11:00:35 sensor-xavier nvargus-daemon[6804]: initialize: focus query failed
Sep 07 11:00:35 sensor-xavier nvargus-daemon[6804]: SCF: Error BadParameter: (propagating from src/services/capture/CaptureServiceDeviceSensor.cpp, function open(), line 139)
Sep 07 11:00:35 sensor-xavier nvargus-daemon[6804]: SCF: Error BadParameter: (propagating from src/services/capture/CaptureServiceDeviceSensor.cpp, function getSourceFromGuid(), line 579)
Sep 07 11:00:35 sensor-xavier nvargus-daemon[6804]: SCF: Error BadParameter: (propagating from src/services/capture/CaptureService.cpp, function addSourceByGuid(), line 437)
Sep 07 11:00:35 sensor-xavier nvargus-daemon[6804]: SCF: Error BadParameter: (propagating from src/api/CameraDriver.cpp, function handleHotplugEvent(), line 336)
Sep 07 11:00:35 sensor-xavier nvargus-daemon[6804]: SCF: Error BadParameter: (propagating from src/api/CameraDriver.cpp, function onDeviceStatusChanged(), line 305)
Sep 07 11:00:35 sensor-xavier nvargus-daemon[6804]: ---- imager: No override file found. ----
Sep 07 11:00:35 sensor-xavier nvargus-daemon[6804]: initializeDevNode: Failed to open dev node '/dev/camera/video5'; No such file or directory, trying alternate default location
Sep 07 11:00:35 sensor-xavier nvargus-daemon[6804]: getModeListLength: Error: mode list uninitialized
Sep 07 11:00:35 sensor-xavier nvargus-daemon[6804]: (NvCamV4l2) Error NotInitialized: No active Pixel Type set (in /dvs/git/dirty/git-master_linux/camera/utils/nvcamv4l2/v4l2_device.cpp, function getModeInfoByIndex(), line 1490)
Sep 07 11:00:35 sensor-xavier nvargus-daemon[6804]: (NvOdmDevice) Error NotInitialized: (propagating from dvs/git/dirty/git-master_linux/camera-partner/imager/src/devices/V4L2SensorNonViCsi.cpp, function loadModeResolution(), line
Sep 07 11:00:35 sensor-xavier nvargus-daemon[6804]: initializeDevNode: Failed to open dev node '/dev/camera/video6'; No such file or directory, trying alternate default location
Sep 07 11:00:35 sensor-xavier nvargus-daemon[6804]: (NvCamV4l2) Error BadParameter: Error opening driver node (/dev/video); Is a directory. (in /dvs/git/dirty/git-master_linux/camera/utils/nvcamv4l2/v4l2_device.cpp, function powerO
Sep 07 11:00:35 sensor-xavier nvargus-daemon[6804]: (NvCamV4l2) Error BadParameter: (propagating from /dvs/git/dirty/git-master_linux/camera/utils/nvcamv4l2/v4l2_device.cpp, function initialize(), line 63)
Sep 07 11:00:35 sensor-xavier nvargus-daemon[6804]: (NvOdmDevice) Error BadParameter: (propagating from dvs/git/dirty/git-master_linux/camera-partner/imager/src/HotplugMonitor.cpp, function getDeviceType(), line 429)
Sep 07 11:00:35 sensor-xavier nvargus-daemon[6804]: handleHotplugCallback: Unknown device type
Sep 07 11:06:18 sensor-xavier nvargus-daemon[6804]: === person_detector_node[8875]: CameraProvider destroyed (0x7f70ab8550)=== person_detector_node[8875]: Connection closed (7F76DF01D0)=== person_detector_node[8875]: Connection cle
Sep 07 11:06:18 sensor-xavier nvargus-daemon[6804]: OFParserListModules: module list: /proc/device-tree/tegra-camera-platform/modules/module1
Sep 07 11:06:18 sensor-xavier nvargus-daemon[6804]: OFParserListModules: module list: /proc/device-tree/tegra-camera-platform/modules/module2
Sep 07 11:06:18 sensor-xavier nvargus-daemon[6804]: OFParserListModules: module list: /proc/device-tree/tegra-camera-platform/modules/module3
Sep 07 11:06:18 sensor-xavier nvargus-daemon[6804]: NvPclHwGetModuleList: WARNING: Could not map module to ISP config string
Sep 07 11:06:18 sensor-xavier nvargus-daemon[6804]: NvPclHwGetModuleList: No module data found
Note: I have included the first two logs as attachments since there is a large number of messages.
