I’m following the Hello AI World tutorial on my newly set up Jetson nano 4gb version. It all went to plan until I tried to find the video feed from my logitech c270 camera using the line
ls /dev/video*
from within the docker container. It says there is no such file. If I run this same line in a seperate terminal outside of the container it shows /dev/video0.
Does the container need to be given access to use the camera, or is there some other way to make it show up within the docker?
Cheers
