I am trying to connect my SAM-M8Q GPS module to the Jetson TX2 and display data throug GPSd. The module is connected to pins 8 and 10 (UART #0). As far as I can tell the port “address” is /dev/ttyS0. I have told GPSd to look for he /dev/ttyS0 port, but it returns no data when connected (I do have a fix on satellites). I think I need to adjust the baud rate for /dev/ttyS0 to 9600, the rate of the module, but setserial won’t allow me to adjust the ports base rate using
setserial /dev/ttyS0 baud_base 9600
. Any help or even links to other tutorials would be greatly appreciated.
