It has a 1080p resolution that should work fine, but I have never succeeded in booting in it. But I’m having the power supply switched to DC input, does it affect the booting?
It possibly means the desktop fails to launch. There are lots of reason that could cause this. But it has no matter with your monitor. When the time your monitor is able to see log, your monitor is supported.
If you want us to analyze, you can try to use the uart console to access to the board and dump dmesg and /var/log/Xog.0.log.
Hi, I solve the issue by connecting Jetson nano to the monitor when I have connected it to my computer by VNC. After doing so, my monitor is able to display the screen and continue to do so directly after boot up. Thanks a lot for the moderator’s help.
