Connecting PCIe capture card turns off the HDMI display
Is there any extra driver needed to install for enable this pcie card?
Could you firstly run the application w/o this card and confirm if this sample can run? Then, you connect this card and try the sample again.
This sample would not require gpu to help render, so if it can work but the desktop does not show, it means the gpu related usecase have some problems.
I haven’t connected the PCIe card so far and I have same error message as #17. The PCIe card requires a driver.
Here is the log file after attaching PCIe capture card and the screen goes blank.
[ 0.493284] tegra-pmc 7000e400.pmc: PMC: Successfully configure bootrom reset commands
[ 0.493601] iommu: Adding device 70012000.se to group 24
[ 0.494383] iommu: Adding device 7000c000.i2c to group 25
[ 0.494651] iommu: Adding device 7000c400.i2c to group 26
[ 0.494924] iommu: Adding device 7000c500.i2c to group 27
[ 0.495191] iommu: Adding device 7000c700.i2c to group 28
[ 0.495500] iommu: Adding device 7000d000.i2c to group 29
[ 0.495759] iommu: Adding device 7000d100.i2c to group 30
[ 0.496069] iommu: Adding device sdhci-tegra.0 to group 31
[ 0.496140] platform sdhci-tegra.0: domain=ffffffc0f9536e58 allocates as[0]=ffffffc0f9bcc4b8
[ 0.497027] iommu: Adding device 700d0000.xudc to group 32
[ 0.501626] vdd-ac-bat: 5000 mV
[ 0.502023] vdd-5v0-sys: 5000 mV
[ 0.503008] vdd-5v0-hdmi: supplied by vdd-5v0-sys
[ 0.503095] vdd-5v0-hdmi: 5000 mV
[ 0.503522] vdd-1v8: 1800 mV
[ 0.503927] vdd-fan: supplied by vdd-5v0-sys
[ 0.503974] vdd-fan: 5000 mV
[ 0.504380] vdd-usb-vbus: supplied by vdd-5v0-sys
[ 0.504454] vdd-usb-vbus: 5000 mV
[ 0.505023] vdd-usb-vbus2: 5000 mV
[ 0.537875] HugeTLB registered 2 MB page size, pre-allocated 0 pages
[ 0.540412] GPIO line 151 (camera-control-output-low) hogged as output/low
[ 0.540484] GPIO line 6 (system-suspend-gpio) hogged as output/low
[ 0.540862] gpiochip_setup_dev: registered GPIOs 0 to 255 on device: gpiochip0 (tegra-gpio)
[ 0.548905] eventlib_kernel: keventlib is initialized, test id: 0
[ 0.549294] SCSI subsystem initialized
[ 0.549547] libata version 3.00 loaded.
[ 0.549878] usbcore: registered new interface driver usbfs
[ 0.549950] usbcore: registered new interface driver hub
[ 0.550040] usbcore: registered new device driver usb
[ 0.554219] max77620 4-003c: PMIC Version OTP:0x35 and ES:0x8
[ 0.555809] random: fast init done
[ 0.560390] vdd-core: 600 <–> 1162 mV at 1075 mV
[ 0.561665] vdd-ddr-1v1: Bringing 1125000uV into 1150000-1150000uV
[ 0.564235] vdd-ddr-1v1: 1150 mV
[ 0.568233] vdd-pre-reg-1v35: 1350 mV
[ 0.572235] vdd-1v8: 1800 mV
[ 0.572519] vdd-1v8: Failed to create debugfs directory
[ 0.576234] avdd-sys-1v2: 1200 mV
[ 0.580232] vdd-pex-1v0: 1050 mV
[ 0.581015] vddio-sdmmc-ap: 1800 <–> 3300 mV at 3300 mV
[ 0.581667] max77620-ldo3: at 3100 mV
[ 0.584237] vdd-rtc: 850 <–> 1100 mV at 1000 mV
[ 0.584917] max77620-ldo5: at 3100 mV
[ 0.585575] max77620-ldo6: at 2800 mV
[ 0.588236] avdd-1v05-pll: 1050 mV
[ 0.592233] avdd-io-hdmi-dp: 1050 mV
[ 0.593776] GPIO line 505 (spmic-default-output-high) hogged as output/high
[ 0.594088] gpiochip_setup_dev: registered GPIOs 504 to 511 on device: gpiochip1 (max77620-gpio)
[ 0.596184] max77620 4-003c: max77620 probe successful
[ 0.598410] i2c i2c-6: Unbalanced pm_runtime_enable!
[ 0.598952] media: Linux media interface: v0.10
[ 0.599021] Linux video capture interface: v2.00
[ 0.599959] pps_core: LinuxPPS API ver. 1 registered
[ 0.599981] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti giometti@linux.it
[ 0.600023] PTP clock support registered
[ 0.603550] tegra_fiq_debugger_init: found FIQ source (IRQ 98)
[ 0.609842] tegra210-emc 7001b000.external-memory-controller: validated EMC DFS table
[ 0.610686] Advanced Linux Sound Architecture Driver Initialized.
[ 0.611346] Bluetooth: Core ver 2.22
[ 0.611414] NET: Registered protocol family 31
[ 0.611432] Bluetooth: HCI device and connection manager initialized
[ 0.611460] Bluetooth: HCI socket layer initialized
[ 0.611482] Bluetooth: L2CAP socket layer initialized
[ 0.611520] Bluetooth: SCO socket layer initialized
[ 0.613159] tegra210_dvfs: no clock found for sdmmc2_ddr
[ 0.613198] tegra210_dvfs: no clock found for sdmmc4_ddr
[ 0.613261] tegra210_dvfs: no clock found for sdmmc1_ddr
[ 0.613291] tegra210_dvfs: no clock found for sdmmc3_ddr
[ 0.615999] tegra_dvfs: Unable to get vdd-cpu rail for step info, defering probe
[ 0.617429] vdd-3v3-sys: supplied by vdd-5v0-sys
[ 0.617517] vdd-3v3-sys: 3300 mV
[ 0.617802] vdd-1v8: supplied by vdd-3v3-sys
[ 0.621146] vdd-usb-vbus2: supplied by vdd-3v3-sys
[ 0.621679] vdd-3v3-sd: supplied by vdd-3v3-sys
[ 0.621733] vdd-3v3-sd: 3300 mV
[ 0.622970] avdd-io-edp-1v05: supplied by avdd-1v05-pll
[ 0.623030] avdd-io-edp-1v05: 1050 mV
[ 0.623479] vdd-usb-hub-en: supplied by vdd-1v8
[ 0.623556] vdd-usb-hub-en: 5000 mV
[ 0.624860] camchar: rtcpu character device driver loaded
[ 0.625751] extcon-gpio-states extcon:extcon@1: Cable state:0, cable id:0
[ 0.627186] clocksource: Switched to clocksource arch_sys_counter
[ 0.667487] VFS: Disk quotas dquot_6.6.0
[ 0.667650] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.668152] nvmap_heap_init: nvmap_heap_init: created heap block cache
[ 0.668621] dma_declare_coherent_resizable_cma_memory:324: resizable heap=vpr, base=0x00000000d7000000, size=0x19000000
[ 0.668667] dma-vpr: heap size is not multiple of cma_chunk_size heap_info->num_chunks (13) rem_chunk_size(0x1000000)
[ 0.668872] cma: enabled page replacement for spfn=d7000, epfn=f0000
[ 0.668896] dma_declare_coherent_resizable_cma_memory:373: resizable cma heap=vpr create successful
[ 0.668922] tegra-carveouts tegra-carveouts: assigned reserved memory node vpr-carveout
[ 0.668972] tegra-carveouts tegra-carveouts: iram :dma coherent mem declare 0x0000000040001000,258048
[ 0.668997] tegra-carveouts tegra-carveouts: assigned reserved memory node iram-carveout
[ 0.669026] nvmap: nvmap_select_cache_ops() nvmap cache ops set to set/ways
[ 0.669048] nvmap_page_pool_init: Total RAM pages: 1012480
[ 0.669065] nvmap_page_pool_init: nvmap page pool size: 126560 pages (494 MB)
[ 0.669167] nvmap_background_zero_thread: PP zeroing thread starting.
[ 0.669634] misc nvmap: created heap iram base 0x0000000040001000 size (252KiB)
[ 0.670560] misc nvmap: created heap vpr base 0x00000000d7000000 size (409600KiB)
[ 0.678698] thermal thermal_zone0: Registering thermal zone thermal_zone0 for type AO-therm
[ 0.679103] thermal thermal_zone1: Registering thermal zone thermal_zone1 for type CPU-therm
[ 0.679401] thermal thermal_zone2: Registering thermal zone thermal_zone2 for type GPU-therm
[ 0.679638] thermal thermal_zone3: Registering thermal zone thermal_zone3 for type PLL-therm
[ 0.679837] thermal thermal_zone4: Registering thermal zone thermal_zone4 for type PMIC-Die
[ 0.680138] pre_t19x_iso_plat_init(): iso emc max clk=1600000KHz
[ 0.680160] pre_t19x_iso_plat_init(): max_iso_bw=33280000KB
[ 0.680609] NET: Registered protocol family 2
[ 0.681604] TCP established hash table entries: 32768 (order: 6, 262144 bytes)
[ 0.681838] TCP bind hash table entries: 32768 (order: 7, 524288 bytes)
[ 0.682351] TCP: Hash tables configured (established 32768 bind 32768)
[ 0.682518] UDP hash table entries: 2048 (order: 4, 65536 bytes)
[ 0.682614] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes)
[ 0.683028] NET: Registered protocol family 1
[ 0.683805] RPC: Registered named UNIX socket transport module.
[ 0.683837] RPC: Registered udp transport module.
[ 0.683853] RPC: Registered tcp transport module.
[ 0.683869] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.683894] PCI: CLS 0 bytes, default 64
[ 0.684126] Trying to unpack rootfs image as initramfs…
[ 0.693164] host1x 50000000.host1x: initialized
[ 0.694978] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[ 0.698296] audit: initializing netlink subsys (disabled)
[ 0.698395] audit: type=2000 audit(0.547:1): initialized
[ 0.699218] workingset: timestamp_bits=46 max_order=20 bucket_order=0
[ 0.709237] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.710741] ntfs: driver 2.1.32 [Flags: R/W].
[ 0.711785] 9p: Installing v9fs 9p2000 file system support
[ 0.714976] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 240)
[ 0.715170] io scheduler noop registered
[ 0.715479] io scheduler cfq registered (default)
[ 0.718167] gic 702f9000.agic: GIC IRQ controller registered
[ 0.720964] iommu: Adding device 702ef000.adsp to group 33
[ 0.726927] iommu: Adding device aconnect@702c0000:adsp_audio to group 34
[ 0.727083] tegra-aconnect aconnect@702c0000: Tegra ACONNECT bus registered
[ 0.727809] tegra-xusb-padctl 7009f000.xusb_padctl: TEGRA_FUSE_SKU_CALIB_0 = 0x91c8c10
[ 0.727844] tegra-xusb-padctl 7009f000.xusb_padctl: TEGRA_FUSE_USB_CALIB_EXT_0 = 0x4
[ 0.729487] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-usb2.0, lane = usb2-0, function = xusb
[ 0.729618] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-usb2.1, lane = usb2-1, function = xusb
[ 0.729746] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-usb2.2, lane = usb2-2, function = xusb
[ 0.729954] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.3, lane = pcie-0, function = pcie-x1
[ 0.730065] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.4, lane = pcie-1, function = pcie-x4
[ 0.730180] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.5, lane = pcie-2, function = pcie-x4
[ 0.730291] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.6, lane = pcie-3, function = pcie-x4
[ 0.730403] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.7, lane = pcie-4, function = pcie-x4
[ 0.730514] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.8, lane = pcie-5, function = xusb
[ 0.730633] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.9, lane = pcie-6, function = xusb
[ 0.737149] tegra-pwm 7000a000.pwm: PWM clk cannot sleep in ops
[ 0.738491] tegra-dfll-pwm 70110000.pwm: DFLL pwm-rate: 12800000
[ 0.740430] tegra-pcie 1003000.pcie-controller: 4x1, 1x1 configuration
[ 0.741759] tegra-pcie 1003000.pcie-controller: PCIE: Enable power rails
[ 0.742134] tegra-pcie 1003000.pcie-controller: probing port 0, using 4 lanes
[ 0.743480] tegra_camera_platform tegra-camera-platform: tegra_camera_probe:camera_platform_driver probe
[ 0.743728] misc tegra_camera_ctrl: tegra_camera_isomgr_register isp_iso_bw=1500000, vi_iso_bw=750000, max_bw=1500000
[ 0.743993] Adding domain tsec-pd to PM domain host1x-pd
[ 0.745901] tegra-pcie 1003000.pcie-controller: probing port 1, using 1 lanes
[ 0.746771] tsec 54500000.tsec: initialized
[ 0.748336] tsec 54100000.tsecb: initialized
[ 0.749111] Adding domain nvdec-pd to PM domain host1x-pd
[ 0.752449] nvdec 54480000.nvdec: initialized
[ 0.753582] Adding domain vic03-pd to PM domain host1x-pd
[ 0.753777] Adding domain msenc-pd to PM domain host1x-pd
[ 0.753958] Adding domain nvjpg-pd to PM domain host1x-pd
[ 0.757851] falcon 54340000.vic: initialized
[ 0.759092] falcon 544c0000.nvenc: initialized
[ 0.760527] falcon 54380000.nvjpg: initialized
[ 0.765168] tegradc tegradc.0: disp0 connected to head0->/host1x/sor1
[ 0.765300] display board info: id 0x0, fab 0x0
[ 0.765370] generic_infoframe_type: 0x87
[ 0.765516] tegradc tegradc.0: DT parsed successfully
[ 0.765574] tegradc tegradc.0: Display dc.ffffff800ab40000 registered with id=0
[ 0.766279] tegradc tegradc.0: Bootloader disp_param detected. Detected mode: 640x480 (on 0x0mm) pclk=25173906
[ 0.769489] tegradc tegradc.0: probed
[ 0.772815] tegra-apbdma 60020000.dma: Tegra20 APB DMA driver register 32 channels
[ 0.777463] tegra-adma 702e2000.adma: Tegra210 ADMA driver registered 10 channels
[ 0.778415] tegra-fuse-burn 7000f800.efuse:efuse-burn: Fuse burn driver initialized
[ 0.778779] kfuse 7000fc00.kfuse: initialized
[ 0.780230] tegra-pmc-iopower pmc-iopower: Regulator supply iopower-dbg-supply not available
[ 0.781182] tegra-pmc-iopower pmc-iopower: NO_IOPOWER setting 0x0
[ 0.782571] tegra-dfll-pwm 70110000.pwm: DFLL_PWM regulator is available now
[ 0.782615] vdd-cpu: 708 <–> 1322 mV at 708 mV
[ 0.783212] pwm-regulator pwm_regulators:pwm-regulator@0: PWM regulator registration passed
[ 0.784998] vdd-gpu: applied init 1000000uV constraint
[ 0.785027] vdd-gpu: 708 <–> 1323 mV at 997 mV
[ 0.785440] pwm-regulator pwm_regulators:pwm-regulator@1: PWM regulator registration passed
[ 0.790059] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[ 0.790250] No Device Node present for smmu client: serial8250 !!
[ 0.790282] platform serial8250: No iommus property found in DT node, got swgids from fixup(101004000)
[ 0.790412] iommu: Adding device serial8250 to group 35
[ 0.794324] console [ttyS0] disabled
[ 0.794476] 70006000.serial: ttyS0 at MMIO 0x70006000 (irq = 63, base_baud = 25500000) is a Tegra
[ 1.168692] tegra-pcie 1003000.pcie-controller: link 0 down, retrying
[ 1.573009] tegra-pcie 1003000.pcie-controller: link 0 down, retrying
[ 1.977321] tegra-pcie 1003000.pcie-controller: link 0 down, retrying
[ 1.979340] tegra-pcie 1003000.pcie-controller: link 0 down, ignoring
[ 1.979754] tegra-pcie 1003000.pcie-controller: PCI host bridge to bus 0000:00
[ 1.979762] pci_bus 0000:00: root bus resource [io 0x0000-0xffff]
[ 1.979767] pci_bus 0000:00: root bus resource [mem 0x13000000-0x1fffffff]
[ 1.979772] pci_bus 0000:00: root bus resource [mem 0x20000000-0x3fffffff pref]
[ 1.979777] pci_bus 0000:00: root bus resource [bus 00-ff]
[ 1.979824] pci 0000:00:02.0: [10de:0faf] type 01 class 0x060400
[ 1.979954] pci 0000:00:02.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 1.980215] pci 0000:00:02.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[ 1.980385] pci 0000:01:00.0: [10ec:8168] type 00 class 0x020000
[ 1.980420] pci 0000:01:00.0: reg 0x10: [io 0x0000-0x00ff]
[ 1.980463] pci 0000:01:00.0: reg 0x18: [mem 0x00000000-0x00000fff 64bit]
[ 1.980493] pci 0000:01:00.0: reg 0x20: [mem 0x00000000-0x00003fff 64bit]
[ 1.980689] pci 0000:01:00.0: supports D1 D2
[ 1.980692] pci 0000:01:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 1.991266] pci_bus 0000:01: busn_res: [bus 01-ff] end is updated to 01
[ 1.991321] pci 0000:00:02.0: BAR 14: assigned [mem 0x13000000-0x130fffff]
[ 1.991326] pci 0000:00:02.0: BAR 13: assigned [io 0x1000-0x1fff]
[ 1.991336] pci 0000:01:00.0: BAR 4: assigned [mem 0x13000000-0x13003fff 64bit]
[ 1.991362] pci 0000:01:00.0: BAR 2: assigned [mem 0x13004000-0x13004fff 64bit]
[ 1.991386] pci 0000:01:00.0: BAR 0: assigned [io 0x1000-0x10ff]
[ 1.991397] pci 0000:00:02.0: PCI bridge to [bus 01]
[ 1.991403] pci 0000:00:02.0: bridge window [io 0x1000-0x1fff]
[ 1.991410] pci 0000:00:02.0: bridge window [mem 0x13000000-0x130fffff]
[ 1.992192] pcieport 0000:00:02.0: Signaling PME through PCIe PME interrupt
[ 1.992197] pci 0000:01:00.0: Signaling PME through PCIe PME interrupt
[ 1.992204] pcie_pme 0000:00:02.0:pcie001: service driver pcie_pme loaded
[ 1.992334] aer 0000:00:02.0:pcie002: service driver aer loaded
[ 3.206924] console [ttyS0] enabled
[ 3.207331] Console: switching to colour frame buffer device 80x30
[ 3.217126] tegradc tegradc.0: fb registered
[ 3.218272] 70006040.serial: ttyTHS1 at MMIO 0x70006040 (irq = 64, base_baud = 0) is a TEGRA_UART
[ 3.218594] serial-tegra 70006200.serial: RX in PIO mode
[ 3.218681] 70006200.serial: ttyTHS2 at MMIO 0x70006200 (irq = 65, base_baud = 0) is a TEGRA_UART
[ 3.219691] [drm] Initialized
[ 3.237268] brd: module loaded
[ 3.251850] loop: module loaded
[ 3.255169] tegra_profiler: version: 1.132, samples/io: 46/26
[ 3.260092] tegradc tegradc.0: DC initialized, skipping tegra_dc_program_mode.
[ 3.260132] tegradc tegradc.0: hdmi: tmds rate:25174K prod-setting:prod_c_hdmi_0m_54m
[ 3.260621] tegradc tegradc.0: hdmi: get RGB quant from REG programmed by BL.
[ 3.260630] tegradc tegradc.0: hdmi: BL set VIC 0
[ 3.260635] tegradc tegradc.0: hdmi: get YCC quant from REG programmed by BL.
[ 3.260953] extcon-disp-state extcon:disp-state: cable 47 state 1
[ 3.260955] Extcon AUX1(HDMI) enable
[ 3.261797] tegradc tegradc.1: disp1 connected to head1->/host1x/sor
[ 3.261868] tegradc tegradc.1: No lt-data, using default setting
[ 3.261893] tegradc tegradc.1: No hpd-gpio in DT
[ 3.261923] tegradc tegradc.1: DT parsed successfully
[ 3.261975] tegradc tegradc.1: Display dc.ffffff800f4c0000 registered with id=1
[ 3.263390] tegradc tegradc.1: dpd enable lookup fail:-19
[ 3.267623] tegradc tegradc.1: probed
[ 3.274781] edid invalid
[ 3.301975] tegradc tegradc.0: nominal-pclk:25174825 parent:25173906 div:1.0 pclk:25173906 24923052~27440532
[ 3.355716] tegradc tegradc.1: fb registered
[ 3.355854] tegra_profiler: auth: init
[ 3.357268] THERMAL EST: found 2 subdevs
[ 3.357273] THERMAL EST num_resources: 0
[ 3.357287] [THERMAL EST subdev 0]
[ 3.357292] [THERMAL EST subdev 1]
[ 3.357747] thermal thermal_zone5: Registering thermal zone thermal_zone5 for type thermal-fan-est
[ 3.357749] THERMAL EST: thz register success.
[ 3.357921] THERMAL EST: end of probe, return err: 0
[ 3.359301] hisi_sas: driver version v1.6
[ 3.363347] tegra-qspi 70410000.spi: Prod settings list not found
[ 3.371758] qspi_mtd spi32766.0: MX25U3235F (4096 Kbytes)
[ 3.371766] qspi_mtd spi32766.0: mtd .name = spi32766.0, .size = 0x400000 (4MiB) .erasesize = 0x00001000 (4KiB) .numeraseregions = 0
[ 3.378461] libphy: Fixed MDIO Bus: probed
[ 3.379718] tun: Universal TUN/TAP device driver, 1.6
[ 3.379720] tun: (C) 1999-2004 Max Krasnyansky maxk@qualcomm.com
[ 3.380806] e1000e: Intel(R) PRO/1000 Network Driver - 3.2.6-k
[ 3.380809] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[ 3.380871] igb: Intel(R) Gigabit Ethernet Network Driver - version 5.4.0-k
[ 3.380873] igb: Copyright (c) 2007-2014 Intel Corporation.
[ 3.380933] igbvf: Intel(R) Gigabit Virtual Function Network Driver - version 2.4.0-k
[ 3.380935] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
[ 3.380986] Intel(R) 10GbE PCI Express Linux Network Driver - version 4.6.4
[ 3.380989] Copyright(c) 1999 - 2017 Intel Corporation.
[ 3.381894] r8168 0000:01:00.0: enabling device (0000 → 0003)
[ 3.381927] r8168 Gigabit Ethernet driver 8.045.08-NAPI loaded
[ 3.396147] r8168 0000:01:00.0 (unnamed net_device) (uninitialized): Invalid ethernet address 00:00:00:00:00:00, trying device tree node
[ 3.396295] r8168 0000:01:00.0 (unnamed net_device) (uninitialized): Found valid ethernet address 00:04:4b:e3:fb:0e from device tree
[ 3.396862] r8168: This product is covered by one or more of the following patents: US6,570,884, US6,115,776, and US6,327,625.
[ 3.396902] r8168 Copyright (C) 2017 Realtek NIC software team nicfae@realtek.com
This program comes with ABSOLUTELY NO WARRANTY; for details, please see http://www.gnu.org/licenses/.
This is free software, and you are welcome to redistribute it under certain conditions; see http://www.gnu.org/licenses/.
[ 3.397488] PPP generic driver version 2.4.2
[ 3.397693] PPP BSD Compression module registered
[ 3.397697] PPP Deflate Compression module registered
[ 3.397743] PPP MPPE Compression module registered
[ 3.397750] NET: Registered protocol family 24
[ 3.397823] usbcore: registered new interface driver r8152
[ 3.397873] usbcore: registered new interface driver asix
[ 3.397938] usbcore: registered new interface driver ax88179_178a
[ 3.397977] usbcore: registered new interface driver cdc_ether
[ 3.398066] usbcore: registered new interface driver net1080
[ 3.398105] usbcore: registered new interface driver cdc_subset
[ 3.398150] usbcore: registered new interface driver zaurus
[ 3.398205] usbcore: registered new interface driver cdc_ncm
[ 3.398406] VFIO - User Level meta-driver version: 0.3
[ 3.399709] ehci_hcd: USB 2.0 ‘Enhanced’ Host Controller (EHCI) Driver
[ 3.399733] ehci-pci: EHCI PCI platform driver
[ 3.399779] ohci_hcd: USB 1.1 ‘Open’ Host Controller (OHCI) Driver
[ 3.399790] ohci-pci: OHCI PCI platform driver
[ 3.399830] ohci-platform: OHCI generic platform driver
[ 3.402557] tegra-xusb 70090000.xusb: USB2 port 0 has OTG_CAP
[ 3.403396] tegra-xusb-padctl 7009f000.xusb_padctl: enabled OTG on UTMI pad 0
[ 3.404596] tegra-xusb 70090000.xusb: extcon 0: ffffffc0f95f0400 id
[ 3.404705] tegra-xusb 70090000.xusb: Direct firmware load for tegra21x_xusb_firmware failed with error -2
[ 3.404708] tegra-xusb 70090000.xusb: Falling back to user helper
[ 3.406060] usbcore: registered new interface driver uas
[ 3.406127] usbcore: registered new interface driver usb-storage
[ 3.406244] usbcore: registered new interface driver usbserial
[ 3.409455] tegra-xudc-new 700d0000.xudc: device count: 1
[ 3.410780] tegra-xudc-new 700d0000.xudc: USB charger detection disabled
[ 3.410792] tegra-xudc-new 700d0000.xudc: vbus state: 0
[ 3.410827] tegra-xudc-new 700d0000.xudc: entering ELPG
[ 3.411096] tegra-xudc-new 700d0000.xudc: entering ELPG done
[ 3.411806] mousedev: PS/2 mouse device common for all mice
[ 3.411892] usbcore: registered new interface driver xpad
[ 3.659637] max77686-rtc max77620-rtc: rtc core: registered max77620-rtc as rtc0
[ 3.671304] rtc rtc1: alarm rtc device
[ 3.671322] tegra_rtc 7000e000.rtc: rtc core: registered 7000e000.rtc as rtc1
[ 3.671351] tegra_rtc 7000e000.rtc: Tegra internal Real Time Clock
[ 3.671902] i2c /dev entries driver
[ 3.673947] imx219 6-0010: tegracam sensor driver:imx219_v2.0.6
[ 3.697969] tegra-vii2c 546c0000.i2c: no acknowledge from address 0x10
[ 3.698039] imx219 6-0010: imx219_board_setup: error during i2c read probe (-121)
[ 3.698067] imx219 6-0010: board setup failed
[ 3.698161] imx219: probe of 6-0010 failed with error -121
[ 3.704114] max77620-power max77620-power: Event recorder REG_NVERC : 0x0
[ 3.744641] tegra_soctherm 700e2000.soctherm: pllx_offset tz:0 max:14, min:2
[ 3.744646] tegra_soctherm 700e2000.soctherm: pllx_offset tz:2 max:8, min:4
[ 3.745083] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 3.745099] tegra_soctherm 700e2000.soctherm: thermtrip: will shut down when cpu reaches 102500 mC
[ 3.745108] tegra_soctherm 700e2000.soctherm: throttrip: will throttle when cpu reaches 100500 mC
[ 3.745239] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 3.745248] tegra_soctherm 700e2000.soctherm: thermtrip: will shut down when gpu reaches 103000 mC
[ 3.745254] tegra_soctherm 700e2000.soctherm: throttrip: will throttle when gpu reaches 101000 mC
[ 3.745396] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 3.745406] tegra_soctherm 700e2000.soctherm: thermtrip: will shut down when pll reaches 127000 mC
[ 3.745411] tegra_soctherm 700e2000.soctherm: throttrip: pll: missing hot temperature
[ 3.745619] tegra_soctherm 700e2000.soctherm: failed to register sensor: -19
[ 3.746390] tegra_aotag tegra-aotag: Registering sensor 0
[ 3.746445] tegra_aotag tegra-aotag: Invalid temp readout
[ 3.746472] tegra_aotag tegra-aotag: Invalid temp readout
[ 3.746488] tegra_aotag tegra-aotag: Bound to TZ : ID 0
[ 3.746496] tegra_aotag tegra-aotag: Probe done [SUCCESS]:0
[ 3.747421] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 3.747440] tegra_dfll_action dfll-cdev-cap: Tegra DFLL ‘cap cooling device’ registered
[ 3.747626] tegra_aotag tegra-aotag: Invalid temp readout
[ 3.747655] tegra_dfll_action dfll-cdev-floor: Tegra DFLL ‘floor cooling device’ registered
[ 3.748097] parse_throttle_dt_data: Num cap clks = 6
[ 3.748103] parse_throttle_dt_data: clk=cclk_g type=2
[ 3.748116] parse_throttle_dt_data: clk=gpu type=4
[ 3.748143] parse_throttle_dt_data: clk=cap.throttle.c2bus type=0
[ 3.748162] parse_throttle_dt_data: clk=cap.throttle.c3bus type=0
[ 3.748183] parse_throttle_dt_data: clk=cap.throttle.sclk type=0
[ 3.748186] parse_throttle_dt_data: clk=emc type=3
[ 3.749691] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 3.749791] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 3.749916] tegra_throttle_probe: probe successful. #cdevs=4
[ 3.750709] FAN dev name: pwm-fan
[ 3.750756] FAN:gpio request success.
[ 3.750829] pwm_fan_driver pwm-fan: cap state:7, cap pwm:255
[ 3.751157] pwm_fan_driver pwm-fan: got pwm for fan. polarity is normal
[ 3.751354] pwm_fan_driver pwm-fan: fan tach request irq success
[ 3.751364] pwm_fan_driver pwm-fan: tach period: 1000
[ 3.751466] pwm_fan_driver pwm-fan: index 0: pwm=0, rpm=0, rru=40, rrd=40, state:2
[ 3.751471] pwm_fan_driver pwm-fan: index 1: pwm=80, rpm=1000, rru=2, rrd=2, state:2
[ 3.751475] pwm_fan_driver pwm-fan: index 2: pwm=120, rpm=2000, rru=1, rrd=1, state:2
[ 3.751479] pwm_fan_driver pwm-fan: index 3: pwm=160, rpm=3000, rru=1, rrd=1, state:2
[ 3.751483] pwm_fan_driver pwm-fan: index 4: pwm=255, rpm=4000, rru=1, rrd=1, state:3
[ 3.751487] pwm_fan_driver pwm-fan: index 5: pwm=255, rpm=5000, rru=1, rrd=1, state:3
[ 3.751491] pwm_fan_driver pwm-fan: index 6: pwm=255, rpm=6000, rru=1, rrd=1, state:3
[ 3.751495] pwm_fan_driver pwm-fan: index 7: pwm=255, rpm=7000, rru=1, rrd=1, state:4
[ 3.751499] pwm_fan_driver pwm-fan: index 8: pwm=255, rpm=10000, rru=1, rrd=1, state:4
[ 3.751503] pwm_fan_driver pwm-fan: index 9: pwm=255, rpm=11000, rru=1, rrd=1, state:4
[ 3.752126] tegra-wdt 60005100.watchdog: Tegra WDT enabled on probe. Timeout = 120 seconds.
[ 3.752489] tegra-wdt 60005100.watchdog: initialized (timeout = 120 sec, nowayout = 1)
[ 3.753403] device-mapper: uevent: version 1.0.3
[ 3.753931] device-mapper: ioctl: 4.35.0-ioctl (2016-06-23) initialised: dm-devel@redhat.com
[ 3.759239] tegra210-cpufreq cpufreq: probe()…completed
[ 3.759962] sdhci: Secure Digital Host Controller Interface driver
[ 3.759963] sdhci: Copyright(c) Pierre Ossman
[ 3.759965] sdhci-pltfm: SDHCI platform and OF driver helper
[ 3.760459] sdhci-tegra sdhci-tegra.0: Got CD GPIO
[ 3.760823] sdhci-tegra sdhci-tegra.0: Client registration for eMC Successful
[ 3.760946] sdhci-tegra sdhci-tegra.0: wakeup init done, cdirq 300
[ 3.765078] tegra-se 70012000.se: tegra_se_probe: complete
[ 3.765609] hidraw: raw HID events driver (C) Jiri Kosina
[ 3.766821] usbcore: registered new interface driver usbhid
[ 3.766822] usbhid: USB HID core driver
[ 3.786155] tegra21x_actmon 6000c800.actmon: in actmon_register()…
[ 3.786321] tegra21x_actmon 6000c800.actmon: initialization Completed for the device mc_all
[ 3.788392] nvpmodel: initialized successfully
[ 3.789446] usbcore: registered new interface driver snd-usb-audio
[ 3.789506] No Device Node present for smmu client: snd-soc-dummy !!
[ 3.789510] platform snd-soc-dummy: No iommus property found in DT node, got swgids from fixup(101004000)
[ 3.789526] iommu: Adding device snd-soc-dummy to group 36
[ 3.811303] mmc0: SDHCI controller on sdhci-tegra.0 [sdhci-tegra.0] using ADMA 64-bit with 64 bit addr
[ 3.823257] OPE platform probe
[ 3.823345] OPE platform probe successful
[ 3.823735] OPE platform probe
[ 3.823819] OPE platform probe successful
[ 3.852887] tegra-asoc: sound: ADMAIF1 <-> ADMAIF1 mapping ok
[ 3.853016] tegra-asoc: sound: ADMAIF2 <-> ADMAIF2 mapping ok
[ 3.853141] tegra-asoc: sound: ADMAIF3 <-> ADMAIF3 mapping ok
[ 3.853268] tegra-asoc: sound: ADMAIF4 <-> ADMAIF4 mapping ok
[ 3.853389] tegra-asoc: sound: ADMAIF5 <-> ADMAIF5 mapping ok
[ 3.853514] tegra-asoc: sound: ADMAIF6 <-> ADMAIF6 mapping ok
[ 3.853635] tegra-asoc: sound: ADMAIF7 <-> ADMAIF7 mapping ok
[ 3.853757] tegra-asoc: sound: ADMAIF8 <-> ADMAIF8 mapping ok
[ 3.853880] tegra-asoc: sound: ADMAIF9 <-> ADMAIF9 mapping ok
[ 3.854002] tegra-asoc: sound: ADMAIF10 <-> ADMAIF10 mapping ok
[ 3.866611] u32 classifier
[ 3.866612] Actions configured
[ 3.866685] Initializing XFRM netlink socket
[ 3.867482] NET: Registered protocol family 10
[ 3.868238] NET: Registered protocol family 17
[ 3.868248] NET: Registered protocol family 15
[ 3.868324] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[ 3.868368] Bluetooth: RFCOMM socket layer initialized
[ 3.868376] Bluetooth: RFCOMM ver 1.11
[ 3.868381] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 3.868385] Bluetooth: HIDP socket layer initialized
[ 3.868404] 9pnet: Installing 9P2000 support
[ 3.868438] Key type dns_resolver registered
[ 3.876150] Registered cp15_barrier emulation handler
[ 3.876208] Registered setend emulation handler
[ 3.877360] registered taskstats version 1
[ 3.877958] Adding domain ve2-pd to PM domain host1x-pd
[ 3.878204] Adding domain ve-pd to PM domain host1x-pd
[ 3.972277] input: tegra-hda HDMI/DP,pcm=3 as /devices/70030000.hda/sound/card0/input0
[ 4.473733] hpd: state 7 (Takeover from bootloader), hpd 0, pending_hpd_evt 1
[ 4.480877] hpd: switching from state 7 (Takeover from bootloader) to state 0 (Reset)
[ 4.482037] isp 54600000.isp: initialized
[ 4.483053] isp 54680000.isp: initialized
[ 4.494734] clk_cbus_recalc_rate: no gbus parent
[ 4.494738] clk_cbus_round_rate: no gbus parent
[ 4.494739] clk_cbus_round_rate: no gbus parent
[ 4.494745] clk_cbus_recalc_rate: no gbus parent
[ 4.494847] clk_cbus_recalc_rate: no gbus parent
[ 4.494850] clk_cbus_round_rate: no gbus parent
[ 4.494851] clk_cbus_round_rate: no gbus parent
[ 4.494854] clk_cbus_recalc_rate: no gbus parent
[ 4.495561] tegra_dvfs: GPU-cap: registered
[ 4.495612] tegra dvfs: vdd-cpu: nominal 1168mV, offset 708000uV, step 19200uV, scaling enabled
[ 4.495614] tegra dvfs: vdd-core: nominal 1075mV, offset 600000uV, step 12500uV, scaling enabled
[ 4.495615] tegra dvfs: vdd-gpu: nominal 1058mV, offset 708000uV, step 10000uV, scaling enabled
[ 4.546621] tegra_dvfs: vdd-gpu-vts: registered
[ 4.568468] hpd: state 0 (Reset), hpd 0, pending_hpd_evt 0
[ 4.573978] tegradc tegradc.1: blank - powerdown
[ 4.578616] extcon-disp-state extcon:disp-state: cable 44 state 0 already set.
[ 4.578674] tegra_core_action core_dvfs_cdev_floor: Tegra CORE DVFS ‘floor cooling device’ registered
[ 4.579300] tegra_core_action core_dvfs_cdev_cap: Tegra CORE DVFS ‘cap cooling device’ registered
[ 4.579807] input: gpio-keys as /devices/gpio-keys/input/input1
[ 4.609886] Extcon DP: HPD disabled
[ 4.613385] hpd: hpd_switch 0
[ 4.616361] hpd: switching from state 0 (Reset) to state 1 (Check Plug)
[ 4.622989] hpd: state 1 (Check Plug), hpd 0, pending_hpd_evt 0
[ 4.628931] hpd: switching from state 1 (Check Plug) to state 3 (Disabled)
[ 4.635801] tegra_rtc 7000e000.rtc: setting system clock to 2000-01-01 01:00:28 UTC (946688428)
[ 4.636738] vi 54080000.vi: vi_probe: ++
[ 4.651775] vi 54080000.vi: initialized
[ 4.658228] vi 54080000.vi: subdev nvcsi–1 bound
[ 4.664326] Disable partitions left on by BL
[ 4.668641] disb
[ 4.670695] bwmgr: missing cdev-type property
[ 4.675166] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 4.684474] DRAM derating cdev registered.
[ 4.689582] vdd-fan: disabling
[ 4.692651] vdd-usb-vbus: disabling
[ 4.696140] vdd-usb-vbus2: disabling
[ 4.699724] avdd-io-edp-1v05: disabling
[ 4.703559] vdd-usb-hub-en: disabling
[ 4.707482] ALSA device list:
[ 4.710447] #0: tegra-hda at 0x70038000 irq 83
[ 4.715068] #1: tegra-snd-t210ref-mobile-rt565x
[ 4.719941] Waiting for root device /dev/mmcblk0p1…
[ 4.828569] mmc0: hw tuning done …
[ 4.832181] mmc0: new ultra high speed SDR50 SDXC card at address aaaa
[ 4.839049] mmcblk0: mmc0:aaaa SL128 119 GiB
[ 4.870560] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12
[ 13.427205] tegra-i2c 7000c700.i2c: pio timed out addr: 0x50 tlen:28 rlen:128
[ 13.434353] tegra-i2c 7000c700.i2c: — register dump for debugging ----
[ 13.441053] tegra-i2c 7000c700.i2c: I2C_CNFG - 0x22c00
[ 13.446188] tegra-i2c 7000c700.i2c: I2C_PACKET_TRANSFER_STATUS - 0x10001
[ 13.452886] tegra-i2c 7000c700.i2c: I2C_FIFO_CONTROL - 0xe0
[ 13.458454] tegra-i2c 7000c700.i2c: I2C_FIFO_STATUS - 0x800040
[ 13.464284] tegra-i2c 7000c700.i2c: I2C_INT_MASK - 0x7d
[ 13.469505] tegra-i2c 7000c700.i2c: I2C_INT_STATUS - 0x0
[ 13.474814] tegra-i2c 7000c700.i2c: i2c transfer timed out addr: 0x50
[ 14.883256] EXT4-fs (mmcblk0p1): 24 orphan inodes deleted
[ 14.888664] EXT4-fs (mmcblk0p1): recovery complete
[ 17.195941] EXT4-fs (mmcblk0p1): mounted filesystem with ordered data mode. Opts: (null)
[ 17.204070] VFS: Mounted root (ext4 filesystem) on device 179:1.
[ 17.218158] devtmpfs: mounted
[ 17.224191] Freeing unused kernel memory: 8512K
[ 17.607711] systemd[1]: System time before build time, advancing clock.
[ 17.652982] cgroup: cgroup2: unknown option “nsdelegate”
[ 17.685600] systemd[1]: systemd 237 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
[ 17.707680] systemd[1]: Detected architecture arm64.
[ 17.739407] systemd[1]: Set hostname to .
[ 17.895174] systemd[1]: File /lib/systemd/system/systemd-journald.service:36 configures an IP firewall (IPAddressDeny=any), but the local system does not support BPF/cgroup based firewalling.
[ 17.912219] systemd[1]: Proceeding WITHOUT firewalling in effect! (This warning is only shown for the first loaded unit using IP firewalling.)
[ 18.149949] random: systemd: uninitialized urandom read (16 bytes read)
[ 18.158259] systemd[1]: Created slice User and Session Slice.
[ 18.164333] random: systemd: uninitialized urandom read (16 bytes read)
[ 18.171127] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 18.178830] random: systemd: uninitialized urandom read (16 bytes read)
[ 18.185472] systemd[1]: Reached target Swap.
[ 18.189863] systemd[1]: Reached target User and Group Name Lookups.
[ 18.198228] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[ 18.339350] EXT4-fs (mmcblk0p1): re-mounted. Opts: (null)
[ 18.477624] systemd-journald[1904]: Received request to flush runtime journal from PID 1
[ 19.299144] random: crng init done
[ 19.302553] random: 7 urandom warning(s) missed due to ratelimiting
[ 19.718565] using random self ethernet address
[ 19.728780] using random host ethernet address
[ 19.810736] tegra-xusb 70090000.xusb: cannot find firmware…retry after 1 second
[ 19.886557] Mass Storage Function, version: 2009/09/11
[ 19.886563] LUN: removable file: (no medium)
[ 19.892862] using random self ethernet address
[ 19.897692] using random host ethernet address
[ 19.908969] rndis0: HOST MAC 2e:eb:67:d8:1c:dc
[ 19.909146] rndis0: MAC 2e:eb:67:d8:1c:dd
[ 19.909732] usb0: HOST MAC 2e:eb:67:d8:1c:de
[ 19.909866] usb0: MAC 2e:eb:67:d8:1c:df
[ 19.909885] tegra-xudc-new 700d0000.xudc: exiting ELPG
[ 19.913066] tegra-xudc-new 700d0000.xudc: exiting ELPG done
[ 19.913084] tegra-xudc-new 700d0000.xudc: ep 0 (type: 0, dir: out) enabled
[ 19.913113] tegra-xudc-new 700d0000.xudc: entering ELPG
[ 19.913336] tegra-xudc-new 700d0000.xudc: entering ELPG done
[ 19.913348] tegra-xudc-new 700d0000.xudc: exiting ELPG
[ 19.913846] tegra-xudc-new 700d0000.xudc: exiting ELPG done
[ 19.913863] tegra-xudc-new 700d0000.xudc: entering ELPG
[ 19.914084] tegra-xudc-new 700d0000.xudc: entering ELPG done
[ 19.950593] l4tbr0: port 1(rndis0) entered blocking state
[ 19.950598] l4tbr0: port 1(rndis0) entered disabled state
[ 19.950753] device rndis0 entered promiscuous mode
[ 19.959037] IPv6: ADDRCONF(NETDEV_UP): rndis0: link is not ready
[ 19.964590] l4tbr0: port 2(usb0) entered blocking state
[ 19.964595] l4tbr0: port 2(usb0) entered disabled state
[ 19.964746] device usb0 entered promiscuous mode
[ 19.974509] IPv6: ADDRCONF(NETDEV_UP): usb0: link is not ready
[ 19.974516] l4tbr0: port 2(usb0) entered blocking state
[ 19.974520] l4tbr0: port 2(usb0) entered forwarding state
[ 20.862295] tegra-xusb 70090000.xusb: Firmware timestamp: 2017-11-03 13:36:19 UTC, Version: 50.20 release
[ 20.862330] tegra-xusb 70090000.xusb: xHCI Host Controller
[ 20.862348] tegra-xusb 70090000.xusb: new USB bus registered, assigned bus number 1
[ 20.863263] tegra-xusb 70090000.xusb: hcc params 0x0184f525 hci version 0x100 quirks 0x00050010
[ 20.863295] tegra-xusb 70090000.xusb: irq 61, io mem 0x70090000
[ 20.863419] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 20.863423] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 20.863426] usb usb1: Product: xHCI Host Controller
[ 20.863429] usb usb1: Manufacturer: Linux 4.9.140-tegra xhci-hcd
[ 20.863431] usb usb1: SerialNumber: 70090000.xusb
[ 20.863867] hub 1-0:1.0: USB hub found
[ 20.863925] hub 1-0:1.0: 5 ports detected
[ 20.864310] tegra-xusb 70090000.xusb: xHCI Host Controller
[ 20.864318] tegra-xusb 70090000.xusb: new USB bus registered, assigned bus number 2
[ 20.864384] usb usb2: We don’t know the algorithms for LPM for this host, disabling LPM.
[ 20.864453] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003
[ 20.864457] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 20.864460] usb usb2: Product: xHCI Host Controller
[ 20.864463] usb usb2: Manufacturer: Linux 4.9.140-tegra xhci-hcd
[ 20.864466] usb usb2: SerialNumber: 70090000.xusb
[ 20.864771] hub 2-0:1.0: USB hub found
[ 20.864796] hub 2-0:1.0: 4 ports detected
[ 20.915205] l4tbr0: port 2(usb0) entered disabled state
[ 20.967234] tegra-xusb-padctl 7009f000.xusb_padctl: power on UTMI pads 1
[ 20.967501] usb usb2: usb_suspend_both: status 0
[ 21.195201] usb 1-2: new high-speed USB device number 2 using tegra-xusb
[ 21.232278] usb 1-2: New USB device found, idVendor=0bda, idProduct=5411
[ 21.232285] usb 1-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 21.232289] usb 1-2: Product: 4-Port USB 2.1 Hub
[ 21.232293] usb 1-2: Manufacturer: Generic
[ 21.233479] hub 1-2:1.0: USB hub found
[ 21.234576] hub 1-2:1.0: 4 ports detected
[ 21.340344] usb 2-1: new SuperSpeed USB device number 2 using tegra-xusb
[ 21.374402] usb 2-1: New USB device found, idVendor=0bda, idProduct=0411
[ 21.374408] usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 21.374412] usb 2-1: Product: 4-Port USB 3.1 Hub
[ 21.374415] usb 2-1: Manufacturer: Generic
[ 21.379956] hub 2-1:1.0: USB hub found
[ 21.381444] hub 2-1:1.0: 4 ports detected
[ 21.523218] usb 1-2.1: new low-speed USB device number 3 using tegra-xusb
[ 21.539256] usb 2-1: usb_suspend_both: status 0
[ 21.539435] usb usb2: usb_suspend_both: status 0
[ 21.564192] usb 1-2.1: New USB device found, idVendor=03f0, idProduct=034a
[ 21.564199] usb 1-2.1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 21.564203] usb 1-2.1: Product: HP Elite USB Keyboard
[ 21.564207] usb 1-2.1: Manufacturer: Chicony
[ 21.574804] input: Chicony HP Elite USB Keyboard as /devices/70090000.xusb/usb1/1-2/1-2.1/1-2.1:1.0/0003:03F0:034A.0001/input/input2
[ 21.631811] hid-generic 0003:03F0:034A.0001: input,hidraw0: USB HID v1.10 Keyboard [Chicony HP Elite USB Keyboard] on usb-70090000.xusb-2.1/input0
[ 21.647057] input: Chicony HP Elite USB Keyboard as /devices/70090000.xusb/usb1/1-2/1-2.1/1-2.1:1.1/0003:03F0:034A.0002/input/input3
[ 21.703440] hid-generic 0003:03F0:034A.0002: input,hidraw1: USB HID v1.10 Device [Chicony HP Elite USB Keyboard] on usb-70090000.xusb-2.1/input1
[ 21.787169] usb 1-2.3: new low-speed USB device number 4 using tegra-xusb
[ 21.815872] usb 1-2.3: New USB device found, idVendor=17ef, idProduct=608d
[ 21.815877] usb 1-2.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 21.815881] usb 1-2.3: Product: Lenovo USB Optical Mouse
[ 21.815883] usb 1-2.3: Manufacturer: PixArt
[ 21.819447] input: PixArt Lenovo USB Optical Mouse as /devices/70090000.xusb/usb1/1-2/1-2.3/1-2.3:1.0/0003:17EF:608D.0003/input/input4
[ 21.819817] hid-generic 0003:17EF:608D.0003: input,hidraw2: USB HID v1.11 Mouse [PixArt Lenovo USB Optical Mouse] on usb-70090000.xusb-2.3/input0
[ 23.667168] tegra-i2c 7000c700.i2c: pio timed out addr: 0x50 tlen:28 rlen:128
[ 23.674380] tegra-i2c 7000c700.i2c: — register dump for debugging ----
[ 23.681304] tegra-i2c 7000c700.i2c: I2C_CNFG - 0x22c00
[ 23.686901] tegra-i2c 7000c700.i2c: I2C_PACKET_TRANSFER_STATUS - 0x10001
[ 23.694026] tegra-i2c 7000c700.i2c: I2C_FIFO_CONTROL - 0xe0
[ 23.699624] tegra-i2c 7000c700.i2c: I2C_FIFO_STATUS - 0x800040
[ 23.705483] tegra-i2c 7000c700.i2c: I2C_INT_MASK - 0x7d
[ 23.710860] tegra-i2c 7000c700.i2c: I2C_INT_STATUS - 0x0
[ 23.716191] tegra-i2c 7000c700.i2c: i2c transfer timed out addr: 0x50
[ 23.930020] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 23.931511] eth0: 0xffffff800a35e000, 00:04:4b:e3:fb:0e, IRQ 404
[ 23.981418] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 26.047389] r8168: eth0: link up
[ 26.047952] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 30.763876] tegradc tegradc.0: blank - powerdown
[ 30.804519] extcon-disp-state extcon:disp-state: cable 47 state 0
[ 30.804531] Extcon AUX1(HDMI) disable
[ 31.316455] tegradc tegradc.0: blank - powerdown
[ 31.676744] tegradc tegradc.0: blank - powerdown
[ 31.947474] tegradc tegradc.0: blank - powerdown
[ 32.222452] tegradc tegradc.0: blank - powerdown
[ 32.492488] tegradc tegradc.0: blank - powerdown
[ 32.764434] tegradc tegradc.0: blank - powerdown
[ 33.031428] tegradc tegradc.0: blank - powerdown
[ 33.298761] tegradc tegradc.0: blank - powerdown
[ 33.564138] tegradc tegradc.0: blank - powerdown
[ 33.907231] tegra-i2c 7000c700.i2c: pio timed out addr: 0x50 tlen:28 rlen:128
[ 33.915572] tegra-i2c 7000c700.i2c: — register dump for debugging ----
[ 33.922688] tegra-i2c 7000c700.i2c: I2C_CNFG - 0x22c00
[ 33.922695] tegra-i2c 7000c700.i2c: I2C_PACKET_TRANSFER_STATUS - 0x10001
[ 33.922698] tegra-i2c 7000c700.i2c: I2C_FIFO_CONTROL - 0xe0
[ 33.922701] tegra-i2c 7000c700.i2c: I2C_FIFO_STATUS - 0x800040
[ 33.922704] tegra-i2c 7000c700.i2c: I2C_INT_MASK - 0x7d
[ 33.922706] tegra-i2c 7000c700.i2c: I2C_INT_STATUS - 0x0
[ 33.922711] tegra-i2c 7000c700.i2c: i2c transfer timed out addr: 0x50
[ 33.982395] tegradc tegradc.0: blank - powerdown
[ 34.252411] tegradc tegradc.0: blank - powerdown
[ 34.520707] tegradc tegradc.0: blank - powerdown
[ 34.791253] tegradc tegradc.0: blank - powerdown
[ 35.065904] tegradc tegradc.0: blank - powerdown
[ 35.335463] tegradc tegradc.0: blank - powerdown
[ 35.605140] tegradc tegradc.0: blank - powerdown
[ 35.890313] tegradc tegradc.0: blank - powerdown
[ 37.877346] tegradc tegradc.0: blank - powerdown
[ 38.789339] tegradc tegradc.0: blank - powerdown
[ 39.065883] tegradc tegradc.0: blank - powerdown
[ 39.337854] tegradc tegradc.0: blank - powerdown
[ 39.610781] tegradc tegradc.0: blank - powerdown
[ 39.871790] tegradc tegradc.0: blank - powerdown
[ 40.145239] tegradc tegradc.0: blank - powerdown
[ 40.419208] tegradc tegradc.0: blank - powerdown
[ 40.688276] tegradc tegradc.0: blank - powerdown
[ 40.961888] tegradc tegradc.0: blank - powerdown
[ 41.233502] tegradc tegradc.0: blank - powerdown
[ 41.507622] tegradc tegradc.0: blank - powerdown
[ 41.778763] tegradc tegradc.0: blank - powerdown
[ 42.047326] tegradc tegradc.0: blank - powerdown
[ 42.337884] tegradc tegradc.0: blank - powerdown
[ 42.617297] tegradc tegradc.0: blank - powerdown
[ 42.888838] tegradc tegradc.0: blank - powerdown
[ 43.163398] tegradc tegradc.0: blank - powerdown
[ 43.433715] tegradc tegradc.0: blank - powerdown
[ 43.711051] tegradc tegradc.0: blank - powerdown
[ 43.980837] tegradc tegradc.0: blank - powerdown
[ 44.147221] tegra-i2c 7000c700.i2c: pio timed out addr: 0x50 tlen:28 rlen:128
[ 44.154458] tegra-i2c 7000c700.i2c: — register dump for debugging ----
[ 44.161189] tegra-i2c 7000c700.i2c: I2C_CNFG - 0x22c00
[ 44.166348] tegra-i2c 7000c700.i2c: I2C_PACKET_TRANSFER_STATUS - 0x10001
[ 44.173070] tegra-i2c 7000c700.i2c: I2C_FIFO_CONTROL - 0xe0
[ 44.178666] tegra-i2c 7000c700.i2c: I2C_FIFO_STATUS - 0x800040
[ 44.184660] tegra-i2c 7000c700.i2c: I2C_INT_MASK - 0x7d
[ 44.189942] tegra-i2c 7000c700.i2c: I2C_INT_STATUS - 0x0
[ 44.195280] tegra-i2c 7000c700.i2c: i2c transfer timed out addr: 0x50
[ 44.259230] tegradc tegradc.0: blank - powerdown
[ 44.531405] tegradc tegradc.0: blank - powerdown
[ 44.800883] tegradc tegradc.0: blank - powerdown
[ 45.073877] tegradc tegradc.0: blank - powerdown
[ 45.345909] tegradc tegradc.0: blank - powerdown
[ 45.618227] tegradc tegradc.0: blank - powerdown
[ 45.887498] tegradc tegradc.0: blank - powerdown
[ 46.161490] tegradc tegradc.0: blank - powerdown
[ 46.436468] tegradc tegradc.0: blank - powerdown
[ 46.707067] tegradc tegradc.0: blank - powerdown
[ 46.982266] tegradc tegradc.0: blank - powerdown
[ 47.254504] tegradc tegradc.0: blank - powerdown
[ 47.529070] tegradc tegradc.0: blank - powerdown
[ 47.798316] tegradc tegradc.0: blank - powerdown
[ 48.071758] tegradc tegradc.0: blank - powerdown
[ 48.346529] tegradc tegradc.0: blank - powerdown
[ 48.621928] tegradc tegradc.0: blank - powerdown
[ 48.902729] tegradc tegradc.0: blank - powerdown
[ 49.173324] tegradc tegradc.0: blank - powerdown
[ 49.451590] tegradc tegradc.0: blank - powerdown
[ 49.723750] tegradc tegradc.0: blank - powerdown
[ 49.995105] tegradc tegradc.0: blank - powerdown
[ 50.267296] tegradc tegradc.0: blank - powerdown
[ 50.536649] tegradc tegradc.0: blank - powerdown
[ 50.812372] tegradc tegradc.0: blank - powerdown
[ 51.086094] tegradc tegradc.0: blank - powerdown
[ 51.358770] tegradc tegradc.0: blank - powerdown
[ 53.866809] tegradc tegradc.0: blank - powerdown
[ 54.140975] tegradc tegradc.0: blank - powerdown
[ 54.387242] tegra-i2c 7000c700.i2c: pio timed out addr: 0x50 tlen:28 rlen:128
[ 54.396303] tegra-i2c 7000c700.i2c: — register dump for debugging ----
[ 54.403158] tegra-i2c 7000c700.i2c: I2C_CNFG - 0x22c00
[ 54.408507] tegra-i2c 7000c700.i2c: I2C_PACKET_TRANSFER_STATUS - 0x10001
[ 54.415248] tegra-i2c 7000c700.i2c: I2C_FIFO_CONTROL - 0xe0
[ 54.415256] tegra-i2c 7000c700.i2c: I2C_FIFO_STATUS - 0x800040
[ 54.415259] tegra-i2c 7000c700.i2c: I2C_INT_MASK - 0x7d
[ 54.415262] tegra-i2c 7000c700.i2c: I2C_INT_STATUS - 0x0
[ 54.415267] tegra-i2c 7000c700.i2c: i2c transfer timed out addr: 0x50
[ 54.454939] tegradc tegradc.0: blank - powerdown
[ 54.729390] tegradc tegradc.0: blank - powerdown
[ 55.004624] tegradc tegradc.0: blank - powerdown
[ 55.275469] tegradc tegradc.0: blank - powerdown
[ 55.547572] tegradc tegradc.0: blank - powerdown
[ 55.820857] tegradc tegradc.0: blank - powerdown
[ 56.092960] tegradc tegradc.0: blank - powerdown
[ 56.372515] tegradc tegradc.0: blank - powerdown
[ 56.646311] tegradc tegradc.0: blank - powerdown
[ 56.919693] tegradc tegradc.0: blank - powerdown
[ 57.197342] tegradc tegradc.0: blank - powerdown
[ 57.473786] tegradc tegradc.0: blank - powerdown
[ 57.746526] tegradc tegradc.0: blank - powerdown
[ 58.019534] tegradc tegradc.0: blank - powerdown
[ 58.294600] tegradc tegradc.0: blank - powerdown
[ 58.567939] tegradc tegradc.0: blank - powerdown
[ 58.842112] tegradc tegradc.0: blank - powerdown
[ 59.117406] tegradc tegradc.0: blank - powerdown
[ 59.395075] tegradc tegradc.0: blank - powerdown
[ 59.667779] tegradc tegradc.0: blank - powerdown
[ 59.942460] tegradc tegradc.0: blank - powerdown
[ 60.215384] tegradc tegradc.0: blank - powerdown
[ 60.499869] tegradc tegradc.0: blank - powerdown
[ 60.774699] tegradc tegradc.0: blank - powerdown
[ 61.051709] tegradc tegradc.0: blank - powerdown
[ 61.330447] tegradc tegradc.0: blank - powerdown
[ 61.688566] tegradc tegradc.0: blank - powerdown
[ 61.966818] tegradc tegradc.0: blank - powerdown
[ 62.248896] tegradc tegradc.0: blank - powerdown
[ 62.521532] tegradc tegradc.0: blank - powerdown
[ 62.797290] tegradc tegradc.0: blank - powerdown
[ 63.074532] tegradc tegradc.0: blank - powerdown
[ 63.346175] tegradc tegradc.0: blank - powerdown
[ 63.620630] tegradc tegradc.0: blank - powerdown
[ 63.890997] tegradc tegradc.0: blank - powerdown
[ 64.167025] tegradc tegradc.0: blank - powerdown
[ 64.451750] tegradc tegradc.0: blank - powerdown
[ 64.627215] tegra-i2c 7000c700.i2c: pio timed out addr: 0x50 tlen:28 rlen:128
[ 64.634395] tegra-i2c 7000c700.i2c: — register dump for debugging ----
[ 64.641140] tegra-i2c 7000c700.i2c: I2C_CNFG - 0x22c00
[ 64.646310] tegra-i2c 7000c700.i2c: I2C_PACKET_TRANSFER_STATUS - 0x10001
[ 64.653034] tegra-i2c 7000c700.i2c: I2C_FIFO_CONTROL - 0xe0
[ 64.658638] tegra-i2c 7000c700.i2c: I2C_FIFO_STATUS - 0x800040
[ 64.664510] tegra-i2c 7000c700.i2c: I2C_INT_MASK - 0x7d
[ 64.669764] tegra-i2c 7000c700.i2c: I2C_INT_STATUS - 0x0
[ 64.675110] tegra-i2c 7000c700.i2c: i2c transfer timed out addr: 0x50
[ 64.730427] tegradc tegradc.0: blank - powerdown
[ 65.007398] tegradc tegradc.0: blank - powerdown
[ 65.289607] tegradc tegradc.0: blank - powerdown
[ 65.565239] tegradc tegradc.0: blank - powerdown
[ 65.845436] tegradc tegradc.0: blank - powerdown
[ 66.116059] tegradc tegradc.0: blank - powerdown
[ 66.394643] tegradc tegradc.0: blank - powerdown
[ 66.671196] tegradc tegradc.0: blank - powerdown
[ 66.957488] tegradc tegradc.0: blank - powerdown
[ 67.232468] tegradc tegradc.0: blank - powerdown
[ 67.509501] tegradc tegradc.0: blank - powerdown
[ 67.795471] tegradc tegradc.0: blank - powerdown
[ 68.076857] tegradc tegradc.0: blank - powerdown
[ 68.355297] tegradc tegradc.0: blank - powerdown
[ 68.645792] tegradc tegradc.0: blank - powerdown
[ 68.922327] tegradc tegradc.0: blank - powerdown
[ 69.208659] tegradc tegradc.0: blank - powerdown
[ 69.480993] tegradc tegradc.0: blank - powerdown
[ 69.761884] tegradc tegradc.0: blank - powerdown
[ 70.051716] tegradc tegradc.0: blank - powerdown
[ 70.341520] tegradc tegradc.0: blank - powerdown
[ 70.626200] tegradc tegradc.0: blank - powerdown
[ 70.906081] tegradc tegradc.0: blank - powerdown
[ 71.201547] tegradc tegradc.0: blank - powerdown
[ 71.480666] tegradc tegradc.0: blank - powerdown
[ 71.773678] tegradc tegradc.0: blank - powerdown
[ 72.052784] tegradc tegradc.0: blank - powerdown
[ 72.342732] tegradc tegradc.0: blank - powerdown
[ 72.633026] tegradc tegradc.0: blank - powerdown
[ 72.910353] tegradc tegradc.0: blank - powerdown
[ 73.190074] tegradc tegradc.0: blank - powerdown
[ 73.473333] tegradc tegradc.0: blank - powerdown
[ 73.755552] tegradc tegradc.0: blank - powerdown
[ 74.046159] tegradc tegradc.0: blank - powerdown
[ 74.333261] tegradc tegradc.0: blank - powerdown
[ 74.627241] tegradc tegradc.0: blank - powerdown
[ 74.867187] tegra-i2c 7000c700.i2c: pio timed out addr: 0x50 tlen:28 rlen:128
[ 74.874356] tegra-i2c 7000c700.i2c: — register dump for debugging ----
[ 74.882779] tegra-i2c 7000c700.i2c: I2C_CNFG - 0x22c00
[ 74.888104] tegra-i2c 7000c700.i2c: I2C_PACKET_TRANSFER_STATUS - 0x10001
[ 74.896440] tegra-i2c 7000c700.i2c: I2C_FIFO_CONTROL - 0xe0
[ 74.902432] tegra-i2c 7000c700.i2c: I2C_FIFO_STATUS - 0x800040
[ 74.908303] tegra-i2c 7000c700.i2c: I2C_INT_MASK - 0x7d
[ 74.908306] tegra-i2c 7000c700.i2c: I2C_INT_STATUS - 0x0
[ 74.908311] tegra-i2c 7000c700.i2c: i2c transfer timed out addr: 0x50
[ 74.936832] tegradc tegradc.0: blank - powerdown
[ 75.226458] tegradc tegradc.0: blank - powerdown
[ 75.506472] tegradc tegradc.0: blank - powerdown
[ 75.795556] tegradc tegradc.0: blank - powerdown
[ 76.075778] tegradc tegradc.0: blank - powerdown
[ 76.372317] tegradc tegradc.0: blank - powerdown
[ 76.661837] tegradc tegradc.0: blank - powerdown
[ 76.942131] tegradc tegradc.0: blank - powerdown
[ 77.224366] tegradc tegradc.0: blank - powerdown
[ 77.507897] tegradc tegradc.0: blank - powerdown
[ 77.785602] tegradc tegradc.0: blank - powerdown
[ 78.066213] tegradc tegradc.0: blank - powerdown
[ 78.357312] tegradc tegradc.0: blank - powerdown
[ 78.644355] tegradc tegradc.0: blank - powerdown
[ 78.918669] tegradc tegradc.0: blank - powerdown
[ 79.205791] tegradc tegradc.0: blank - powerdown
[ 79.487253] tegradc tegradc.0: blank - powerdown
[ 79.769818] tegradc tegradc.0: blank - powerdown
[ 80.059593] tegradc tegradc.0: blank - powerdown
[ 80.340199] tegradc tegradc.0: blank - powerdown
[ 80.631365] tegradc tegradc.0: blank - powerdown
[ 80.908776] tegradc tegradc.0: blank - powerdown
[ 81.187633] tegradc tegradc.0: blank - powerdown
[ 81.468399] tegradc tegradc.0: blank - powerdown
[ 81.755377] tegradc tegradc.0: blank - powerdown
[ 82.049065] tegradc tegradc.0: blank - powerdown
[ 82.333941] tegradc tegradc.0: blank - powerdown
[ 82.571799] usb 1-2.3: USB disconnect, device number 4
[ 84.067727] tegradc tegradc.0: blank - powerdown
[ 84.075064] usb 1-2.3: new low-speed USB device number 5 using tegra-xusb
[ 84.099512] usb 1-2.3: New USB device found, idVendor=17ef, idProduct=608d
[ 84.099518] usb 1-2.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 84.099522] usb 1-2.3: Product: Lenovo USB Optical Mouse
[ 84.099525] usb 1-2.3: Manufacturer: PixArt
[ 84.103329] input: PixArt Lenovo USB Optical Mouse as /devices/70090000.xusb/usb1/1-2/1-2.3/1-2.3:1.0/0003:17EF:608D.0004/input/input5
[ 84.103969] hid-generic 0003:17EF:608D.0004: input,hidraw2: USB HID v1.11 Mouse [PixArt Lenovo USB Optical Mouse] on usb-70090000.xusb-2.3/input0
[ 84.360098] tegradc tegradc.0: blank - powerdown
[ 84.641835] tegradc tegradc.0: blank - powerdown
[ 84.932486] tegradc tegradc.0: blank - powerdown
[ 85.107023] tegra-i2c 7000c700.i2c: pio timed out addr: 0x50 tlen:28 rlen:128
[ 85.114172] tegra-i2c 7000c700.i2c: — register dump for debugging ----
[ 85.120957] tegra-i2c 7000c700.i2c: I2C_CNFG - 0x22c00
[ 85.126120] tegra-i2c 7000c700.i2c: I2C_PACKET_TRANSFER_STATUS - 0x10001
[ 85.132845] tegra-i2c 7000c700.i2c: I2C_FIFO_CONTROL - 0xe0
[ 85.138433] tegra-i2c 7000c700.i2c: I2C_FIFO_STATUS - 0x800040
[ 85.144275] tegra-i2c 7000c700.i2c: I2C_INT_MASK - 0x7d
[ 85.149511] tegra-i2c 7000c700.i2c: I2C_INT_STATUS - 0x0
[ 85.154833] tegra-i2c 7000c700.i2c: i2c transfer timed out addr: 0x50
[ 85.281504] tegradc tegradc.0: blank - powerdown
[ 85.574330] tegradc tegradc.0: blank - powerdown
[ 85.866125] tegradc tegradc.0: blank - powerdown
[ 86.159946] tegradc tegradc.0: blank - powerdown
[ 86.447646] tegradc tegradc.0: blank - powerdown
[ 86.732008] tegradc tegradc.0: blank - powerdown
[ 87.024859] tegradc tegradc.0: blank - powerdown
[ 87.301744] tegradc tegradc.0: blank - powerdown
[ 87.579662] tegradc tegradc.0: blank - powerdown
[ 87.855894] tegradc tegradc.0: blank - powerdown
[ 88.149548] tegradc tegradc.0: blank - powerdown
[ 88.438014] tegradc tegradc.0: blank - powerdown
[ 88.730167] tegradc tegradc.0: blank - powerdown
[ 89.010599] tegradc tegradc.0: blank - powerdown
[ 89.289487] tegradc tegradc.0: blank - powerdown
[ 89.570020] tegradc tegradc.0: blank - powerdown
[ 89.853656] tegradc tegradc.0: blank - powerdown
[ 90.146915] tegradc tegradc.0: blank - powerdown
[ 90.430290] tegradc tegradc.0: blank - powerdown
[ 90.720884] tegradc tegradc.0: blank - powerdown
[ 91.013970] tegradc tegradc.0: blank - powerdown
[ 91.306956] tegradc tegradc.0: blank - powerdown
[ 91.603473] tegradc tegradc.0: blank - powerdown
[ 91.898658] tegradc tegradc.0: blank - powerdown
[ 92.191241] tegradc tegradc.0: blank - powerdown
[ 92.485968] tegradc tegradc.0: blank - powerdown
[ 92.765752] tegradc tegradc.0: blank - powerdown
[ 93.058086] tegradc tegradc.0: blank - powerdown
[ 93.335644] tegradc tegradc.0: blank - powerdown
[ 93.617309] tegradc tegradc.0: blank - powerdown
[ 93.912312] tegradc tegradc.0: blank - powerdown
[ 94.195214] tegradc tegradc.0: blank - powerdown
[ 94.474058] tegradc tegradc.0: blank - powerdown
[ 94.759117] tegradc tegradc.0: blank - powerdown
[ 95.059807] tegradc tegradc.0: blank - powerdown
[ 95.346672] tegra-i2c 7000c700.i2c: pio timed out addr: 0x50 tlen:28 rlen:128
[ 95.353837] tegra-i2c 7000c700.i2c: — register dump for debugging ----
[ 95.353842] tegra-i2c 7000c700.i2c: I2C_CNFG - 0x22c00
[ 95.353845] tegra-i2c 7000c700.i2c: I2C_PACKET_TRANSFER_STATUS - 0x10001
[ 95.353848] tegradc tegradc.0: blank - powerdown
[ 95.353850] tegra-i2c 7000c700.i2c: I2C_FIFO_CONTROL - 0xe0
[ 95.353852] tegra-i2c 7000c700.i2c: I2C_FIFO_STATUS - 0x800040
[ 95.353855] tegra-i2c 7000c700.i2c: I2C_INT_MASK - 0x7d
[ 95.353858] tegra-i2c 7000c700.i2c: I2C_INT_STATUS - 0x0
[ 95.353868] tegra-i2c 7000c700.i2c: i2c transfer timed out addr: 0x50
[ 95.697298] tegradc tegradc.0: blank - powerdown
[ 95.992589] tegradc tegradc.0: blank - powerdown
[ 96.275046] tegradc tegradc.0: blank - powerdown
[ 96.572137] tegradc tegradc.0: blank - powerdown
[ 96.857691] tegradc tegradc.0: blank - powerdown
[ 97.157795] tegradc tegradc.0: blank - powerdown
[ 97.450141] tegradc tegradc.0: blank - powerdown
[ 97.733152] tegradc tegradc.0: blank - powerdown
[ 98.032180] tegradc tegradc.0: blank - powerdown
[ 98.325864] tegradc tegradc.0: blank - powerdown
[ 98.620940] tegradc tegradc.0: blank - powerdown
[ 98.921089] tegradc tegradc.0: blank - powerdown
[ 99.213227] tegradc tegradc.0: blank - powerdown
[ 99.509358] tegradc tegradc.0: blank - powerdown
[ 99.805229] tegradc tegradc.0: blank - powerdown
[ 100.103246] tegradc tegradc.0: blank - powerdown
[ 100.405373] tegradc tegradc.0: blank - powerdown
[ 100.698397] tegradc tegradc.0: blank - powerdown
[ 100.995682] tegradc tegradc.0: blank - powerdown
[ 101.293902] tegradc tegradc.0: blank - powerdown
[ 101.594714] tegradc tegradc.0: blank - powerdown
[ 101.896200] tegradc tegradc.0: blank - powerdown
[ 102.191639] tegradc tegradc.0: blank - powerdown
[ 102.493888] tegradc tegradc.0: blank - powerdown
[ 102.792215] tegradc tegradc.0: blank - powerdown
[ 103.094163] tegradc tegradc.0: blank - powerdown
[ 103.393713] tegradc tegradc.0: blank - powerdown
[ 103.693626] tegradc tegradc.0: blank - powerdown
[ 103.992574] tegradc tegradc.0: blank - powerdown
[ 104.293116] tegradc tegradc.0: blank - powerdown
[ 104.590727] tegradc tegradc.0: blank - powerdown
[ 104.891280] tegradc tegradc.0: blank - powerdown
[ 105.188058] tegradc tegradc.0: blank - powerdown
[ 105.487998] tegradc tegradc.0: blank - powerdown
[ 105.586524] tegra-i2c 7000c700.i2c: pio timed out addr: 0x50 tlen:28 rlen:128
[ 105.593685] tegra-i2c 7000c700.i2c: — register dump for debugging ----
[ 105.593694] tegra-i2c 7000c700.i2c: I2C_CNFG - 0x22c00
[ 105.593697] tegra-i2c 7000c700.i2c: I2C_PACKET_TRANSFER_STATUS - 0x10001
[ 105.593700] tegra-i2c 7000c700.i2c: I2C_FIFO_CONTROL - 0xe0
[ 105.593702] tegra-i2c 7000c700.i2c: I2C_FIFO_STATUS - 0x800040
[ 105.593705] tegra-i2c 7000c700.i2c: I2C_INT_MASK - 0x7d
[ 105.593707] tegra-i2c 7000c700.i2c: I2C_INT_STATUS - 0x0
[ 105.593712] tegra-i2c 7000c700.i2c: i2c transfer timed out addr: 0x50
[ 105.850257] tegradc tegradc.0: blank - powerdown
[ 106.149412] tegradc tegradc.0: blank - powerdown
[ 106.433882] tegradc tegradc.0: blank - powerdown
[ 106.731721] tegradc tegradc.0: blank - powerdown
[ 107.020983] tegradc tegradc.0: blank - powerdown
[ 107.323920] tegradc tegradc.0: blank - powerdown
[ 107.647734] tegradc tegradc.0: blank - powerdown
[ 107.929956] tegradc tegradc.0: blank - powerdown
[ 108.217605] tegradc tegradc.0: blank - powerdown
[ 108.523546] tegradc tegradc.0: blank - powerdown
[ 108.822188] tegradc tegradc.0: blank - powerdown
[ 109.106204] tegradc tegradc.0: blank - powerdown
[ 109.408931] tegradc tegradc.0: blank - powerdown
[ 109.695170] tegradc tegradc.0: blank - powerdown
[ 109.999764] tegradc tegradc.0: blank - powerdown
[ 110.303563] tegradc tegradc.0: blank - powerdown
[ 110.607150] tegradc tegradc.0: blank - powerdown
[ 110.906447] tegradc tegradc.0: blank - powerdown
[ 111.210838] tegradc tegradc.0: blank - powerdown
[ 111.498901] tegradc tegradc.0: blank - powerdown
[ 111.802737] tegradc tegradc.0: blank - powerdown
[ 112.110178] tegradc tegradc.0: blank - powerdown
[ 112.414177] tegradc tegradc.0: blank - powerdown
[ 112.721232] tegradc tegradc.0: blank - powerdown
[ 113.021701] tegradc tegradc.0: blank - powerdown
[ 113.559349] tegradc tegradc.0: blank - powerdown
[ 114.533594] tegradc tegradc.0: blank - powerdown
[ 115.518690] tegradc tegradc.0: blank - powerdown
[ 115.821354] tegradc tegradc.0: blank - powerdown
[ 115.826383] tegra-i2c 7000c700.i2c: pio timed out addr: 0x50 tlen:28 rlen:128
[ 115.833579] tegra-i2c 7000c700.i2c: — register dump for debugging ----
[ 115.840394] tegra-i2c 7000c700.i2c: I2C_CNFG - 0x22c00
[ 115.845858] tegra-i2c 7000c700.i2c: I2C_PACKET_TRANSFER_STATUS - 0x10001
[ 115.852624] tegra-i2c 7000c700.i2c: I2C_FIFO_CONTROL - 0xe0
[ 115.858242] tegra-i2c 7000c700.i2c: I2C_FIFO_STATUS - 0x800040
[ 115.864109] tegra-i2c 7000c700.i2c: I2C_INT_MASK - 0x7d
[ 115.869372] tegra-i2c 7000c700.i2c: I2C_INT_STATUS - 0x0
[ 115.874710] tegra-i2c 7000c700.i2c: i2c transfer timed out addr: 0x50
[ 116.137351] tegradc tegradc.0: blank - powerdown
[ 116.440864] tegradc tegradc.0: blank - powerdown
[ 116.747414] tegradc tegradc.0: blank - powerdown
[ 117.054105] tegradc tegradc.0: blank - powerdown
[ 117.354562] tegradc tegradc.0: blank - powerdown
[ 117.657780] tegradc tegradc.0: blank - powerdown
[ 117.961657] tegradc tegradc.0: blank - powerdown
[ 118.264181] tegradc tegradc.0: blank - powerdown
[ 118.567957] tegradc tegradc.0: blank - powerdown
[ 118.870425] tegradc tegradc.0: blank - powerdown
[ 119.169980] tegradc tegradc.0: blank - powerdown
[ 119.477035] tegradc tegradc.0: blank - powerdown
[ 119.777678] tegradc tegradc.0: blank - powerdown
[ 120.077239] tegradc tegradc.0: blank - powerdown
[ 120.385046] tegradc tegradc.0: blank - powerdown
[ 120.686097] tegradc tegradc.0: blank - powerdown
[ 120.986452] tegradc tegradc.0: blank - powerdown
[ 121.293103] tegradc tegradc.0: blank - powerdown
[ 121.605153] tegradc tegradc.0: blank - powerdown
[ 121.908005] tegradc tegradc.0: blank - powerdown
[ 122.212488] tegradc tegradc.0: blank - powerdown
[ 122.513918] tegradc tegradc.0: blank - powerdown
[ 122.816560] tegradc tegradc.0: blank - powerdown
[ 123.124621] tegradc tegradc.0: blank - powerdown
[ 123.427485] tegradc tegradc.0: blank - powerdown
[ 123.732118] tegradc tegradc.0: blank - powerdown
[ 124.036339] tegradc tegradc.0: blank - powerdown
[ 124.344886] tegradc tegradc.0: blank - powerdown
[ 124.650657] tegradc tegradc.0: blank - powerdown
[ 124.956405] tegradc tegradc.0: blank - powerdown
[ 125.265810] tegradc tegradc.0: blank - powerdown
[ 125.569265] tegradc tegradc.0: blank - powerdown
[ 125.877188] tegradc tegradc.0: blank - powerdown
[ 126.066330] tegra-i2c 7000c700.i2c: pio timed out addr: 0x50 tlen:28 rlen:128
[ 126.073487] tegra-i2c 7000c700.i2c: — register dump for debugging ----
[ 126.080236] tegra-i2c 7000c700.i2c: I2C_CNFG - 0x22c00
[ 126.085401] tegra-i2c 7000c700.i2c: I2C_PACKET_TRANSFER_STATUS - 0x10001
[ 126.092119] tegra-i2c 7000c700.i2c: I2C_FIFO_CONTROL - 0xe0
[ 126.097710] tegra-i2c 7000c700.i2c: I2C_FIFO_STATUS - 0x800040
[ 126.103562] tegra-i2c 7000c700.i2c: I2C_INT_MASK - 0x7d
[ 126.108803] tegra-i2c 7000c700.i2c: I2C_INT_STATUS - 0x0
[ 126.114138] tegra-i2c 7000c700.i2c: i2c transfer timed out addr: 0x50
What did you do in#24…?
Your error log is totally different from previous log. Now it is obvious that the display driver is down due to i2c error…
I have installed the PCIe capture card driver and attached the PCIe card. Also, used SSH connection for checking the log. Is there a way to address this issue?
btw, is your previous log the full log? The forum has length limitation of each comment and maybe cut of the log if exceed.
yes, I have posted the full log file.
Let me clarify each comment first.
Please tell us what is the usecase for log in #7. Did you plug the pcie capture card but not have the driver? Is this the case that HDMI is powered on but black screen?
Then in #24, in comparison with #7, do you only install the driver? I think even hdmi power is not ON now. Could you confirm?
It is more like a hardware compatibility issue as some other pcie cards which would affect the i2c functionality…
In log #7, I have used a different monitor with HDMI display output and the PCIe capture card is hot plugged and the screen goes blank after connecting. I have not installed the PCIe driver in this case.
In the log #24, I have changed the monitor and used display port without connecting HDMI and I have connected PCIe capture card before turning ON the Nano board and also, installed PCIe driver. The screen remains blank and I have made an SSH connection to get the log.
I have no idea about your log now. tegradc.1 maps to DP and tegradc.0 maps to HDMI if you are using default driver dtb.
No idea why you claim you are using a DP in #24 but the log is totally from HDMI port…
Actually, none of your log pasted here indicates you are using DP port.
As for your card, I think it is like some other specific card that would affect I2C. We will check if any workaround. But before we start the investigation, please help clarify my previous question first.
In #24 I am using a Display port as output and the PCIe capture card is connected. FYI, the PCIe capture card consists of a HDMI input port. In #24 the HDMI display output is not connected.
In #7 only HDMI display output is connected.
I have checked xrandr before connecting PCIe card. Kindly, check #17 to confirm that DP is connected.
I think it is trying to map to tegradc.0 and failing even though the DP is connected.
Link for the PCIe: Eco Capture HDMI 4K M.2 - Magewell
Dronzer,
Why are you using DP port in #24? I think it makes the test result a little messy here.
If #24 is true, the case becomes that no HDMI monitors are needed to reproduce this issue. Since HDMI port itself has lots of error but you said there was no HDMI connected.
The the test results so far:
  1. PCIe card + adapter + HDMI and no driver → It should be #7,right?
  2. PCIe card + adapter + HDMI + driver → no such test.
  3. Adapter + HDMI → no issue, right?
  4. PCIe card + adapter + DP + driver → somehow the HDMI driver has error and i2c has error based on #24.
  5. PCIe card+ adapter + DP and no driver → no such test.
  6. PCIe card + adapter + no monitor + driver → no such test
Case 6 is a test I want to know after your result in #24. It would be better if you could provide the result of 2,5,6.
The Nano board completely lost display even without the PCIe card. Sadly, I am not able to establish SSH connection.But the power LED is turned On. Any Suggestions?
Dronzer,
I think you need to reflash the board.
Sure, I will reflash and update you on the issue. Thank you very much for your time.
Reconnecting the SD Card worked. But, sadly no display. I will add few more tests.
Test: NO PCIe card + No Adapter + No HDMI + DP port + Driver + SSH connection = blank screen
testwithoutPCIe.txt (64.6 KB)
#37 is obviously the correct log because DP driver has log now while #24 does not.
[ 5.655411] tegradc tegradc.1: DP : Prod set failed
[ 5.659061] tegradc tegradc.1: dp: aux write defer (0x10020000) -- 6
[ 5.660731] tegradc tegradc.1: dp: aux write defer (0x10020000) -- 6
[ 5.663771] dp lt: state 4 (link training fail/disable), pending_lt_evt 1
[ 5.663773] dp lt: switching from state 4 (link training fail/disable) to state 0 (Reset)
[ 5.663775] dp lt: state 0 (Reset), pending_lt_evt 0
[ 5.665597] tegradc tegradc.1: DP : Prod set failed
[ 5.665739] dp lt: switching from state 0 (Reset) to state 2 (clock recovery)
[ 5.665742] dp lt: state 2 (clock recovery), pending_lt_evt 0
[ 5.666186] dp lt: config: lane 0: vs level: 0, pe level: 0, pc2 level: 0
[ 5.666194] dp lt: config: lane 1: vs level: 0, pe level: 0, pc2 level: 0
[ 5.666202] dp lt: config: lane 2: vs level: 0, pe level: 0, pc2 level: 0
[ 5.666211] dp lt: config: lane 3: vs level: 0, pe level: 0, pc2 level: 0
Btw, your log is cut off by the forum system…
Is there anyway I could send you all the logs?
You could attach the log after you file a comment.
For example, move the cursor to the right upper corner of #39, you will see a button to add attachment.
