Connecting the jetson orin nano's battery
I plan to use the Orin nano outdoors.
To do so, I need to be able to power it outdoors.
Will a 20000mAh, 65W power bank with a type C connection work?
Also, if not, would it be better to buy a 220v ups?
Orin nano power supply voltage level is 5V-20V. And 65W is OK.
Are you saying it’s okay to use a product like this to make a C to C connection?
Baseus 65W 30000mAh
What I said is the spec of power supply. Your product would be ok if it can fit the spec.
