Hello, I would like to open a port to connect to my Jetbot from a remote network. Is this possible? If so, what port is required to connect from the outside? I want to use JupyterLab with this.
JetBot uses 8888 to be accessed from the browser.
Then by configuration of port mapping at your network, you may access that from the remote side.
Just guess, I did not try this.
I’ll try this out, thanks!
you can use ngrok to access from outside your local network
