On standard x86_64 linux, and on raspbian you can use USB OTG to connect to one or more Rpi Zero’s. I am assuming the same is true for Xavier dev kit since it’s running Ubuntu 18.04?
If I were to connect a USB type C hub into the Xavier, would it be able to assign IP addresses to two different Pi Zero’s?
I am looking for a reasonably priced solution to attach multiple cameras to the Xavier board. I already have several Pi zero’s and cameras available.
I have browsed the multi-camera solutions here [url]Jetson AGX Xavier - eLinux.org but they are more than I would like to spend for this particular proof of concept project.
I suppose I could try to connect multiple logitech c920 (webcams) over USB hub. Would that work do you think?
These cameras would be used in object detection and localization using a YOLOv3 model with pytorch.
