Connecting USB devices to the M.2 Key E
Hello, I need to add more USB connectors to my board, and using a USB hub is too unstable, because a USB connector is just too unreliable. I want to connect a USB hub adapter to the M.2 Key E that is connected to the WiFi, and I want to know if that is even possible before I go look for one.
I did find a M.2 extender and a M.2 to PCI-E adapter, which I confused as a USB adapter because of the same connections, but that didn’t work of course.
Is it even possible to communicate through the Key E like a USB? is the Data transfer viable?
This is the extender I found : https://www.amazon.com/-/he/dp/B07DZF1W55/ref=ex_alt_wg_d?_encoding=UTF8&pd_rd_i=B07DZF1W55&psc=1&pd_rd_w=uOY78&pf_rd_p=4e1b46a8-daf9-4433-b97e-d6df97cf3699&pf_rd_r=JV9R7X5TSGXEDGAZ2T48&pd_rd_wg=3q9to&pd_rd_r=4d59cc92-d0e3-4eda-a5c7-1ed58df89679&content-id=amzn1.sym.4e1b46a8-daf9-4433-b97e-d6df97cf3699
and this is the PCIE adapter I found: https://www.amazon.com/BEYIMEI-M-2-Interface-Bitcoin-Ethereum/dp/B09YHDPSC8?th=1
I need something like the PCIE adapter but with a normal USB2/3 outputs
Sorry for the late response.
Hi, we dont have recommendation on this. For Jetson itself, the PCIe and USB ports are available for external devices, but customer might need to tune the driver.
