Connection errored out. issue when launch Chat with RTX
Getting Below Error When Trying Run the Chat With RTX program
  1. Tried Disable Firewall and running (Both windows and Kaspersky)
  2. Launching Using a VPN
Laptop Spec is i9-13900HX with RTX 4070 8 GB GPU and 32 GB RAM
Screenshot Attached
Termonal Output below
To create a public link, set share=True in launch().
ERROR: Exception in ASGI application
File “C:\Users\USER\AppData\Local\NVIDIA\ChatWithRTX\env_nvd_rag\lib\site-packages\pydantic\type_adapter.py”, line 165, in init
core_schema = _getattr_no_parents(type, ‘pydantic_core_schema’)
File “C:\Users\USER\AppData\Local\NVIDIA\ChatWithRTX\env_nvd_rag\lib\site-packages\pydantic\type_adapter.py”, line 97, in _getattr_no_parents
raise AttributeError(attribute)
AttributeError: pydantic_core_schema
During handling of the above exception, another exception occurred:
File “C:\Users\USER\AppData\Local\NVIDIA\ChatWithRTX\env_nvd_rag\lib\site-packages\uvicorn\protocols\http\h11_impl.py”, line 406, in run_asgi
result = await app( # type: ignore[func-returns-value]
File “C:\Users\USER\AppData\Local\NVIDIA\ChatWithRTX\env_nvd_rag\lib\site-packages\uvicorn\middleware\proxy_headers.py”, line 70, in call
return await self.app(scope, receive, send)
File “C:\Users\USER\AppData\Local\NVIDIA\ChatWithRTX\env_nvd_rag\lib\site-packages\fastapi\applications.py”, line 1054, in call
await super().call(scope, receive, send)
File “C:\Users\USER\AppData\Local\NVIDIA\ChatWithRTX\env_nvd_rag\lib\site-packages\starlette\applications.py”, line 113, in call
await self.middleware_stack(scope, receive, send)
File “C:\Users\USER\AppData\Local\NVIDIA\ChatWithRTX\env_nvd_rag\lib\site-packages\starlette\middleware\errors.py”, line 187, in call
raise exc
File “C:\Users\USER\AppData\Local\NVIDIA\ChatWithRTX\env_nvd_rag\lib\site-packages\starlette\middleware\errors.py”, line 165, in call
File “C:\Users\USER\AppData\Local\NVIDIA\ChatWithRTX\env_nvd_rag\lib\site-packages\starlette\middleware\cors.py”, line 93, in call
await self.simple_response(scope, receive, send, request_headers=headers)
File “C:\Users\USER\AppData\Local\NVIDIA\ChatWithRTX\env_nvd_rag\lib\site-packages\starlette\middleware\cors.py”, line 144, in simple_response
File “C:\Users\USER\AppData\Local\NVIDIA\ChatWithRTX\env_nvd_rag\lib\site-packages\starlette\middleware\exceptions.py”, line 62, in call
await wrap_app_handling_exceptions(self.app, conn)(scope, receive, send)
File “C:\Users\USER\AppData\Local\NVIDIA\ChatWithRTX\env_nvd_rag\lib\site-packages\starlette_exception_handler.py”, line 62, in wrapped_app
raise exc
File “C:\Users\USER\AppData\Local\NVIDIA\ChatWithRTX\env_nvd_rag\lib\site-packages\starlette_exception_handler.py”, line 51, in wrapped_app
await app(scope, receive, sender)
File “C:\Users\USER\AppData\Local\NVIDIA\ChatWithRTX\env_nvd_rag\lib\site-packages\starlette\routing.py”, line 715, in call
File “C:\Users\USER\AppData\Local\NVIDIA\ChatWithRTX\env_nvd_rag\lib\site-packages\starlette\routing.py”, line 735, in app
await route.handle(scope, receive, send)
File “C:\Users\USER\AppData\Local\NVIDIA\ChatWithRTX\env_nvd_rag\lib\site-packages\starlette\routing.py”, line 288, in handle
File “C:\Users\USER\AppData\Local\NVIDIA\ChatWithRTX\env_nvd_rag\lib\site-packages\starlette\routing.py”, line 76, in app
await wrap_app_handling_exceptions(app, request)(scope, receive, send)
raise exc
File “C:\Users\USER\AppData\Local\NVIDIA\ChatWithRTX\env_nvd_rag\lib\site-packages\starlette\routing.py”, line 73, in app
response = await f(request)
File “C:\Users\USER\AppData\Local\NVIDIA\ChatWithRTX\env_nvd_rag\lib\site-packages\fastapi\routing.py”, line 291, in app
solved_result = await solve_dependencies(
File “C:\Users\USER\AppData\Local\NVIDIA\ChatWithRTX\env_nvd_rag\lib\site-packages\fastapi\dependencies\utils.py”, line 656, in solve_dependencies
) = await request_body_to_args( # body_params checked above
File “C:\Users\USER\AppData\Local\NVIDIA\ChatWithRTX\env_nvd_rag\lib\site-packages\fastapi\dependencies\utils.py”, line 881, in request_body_to_args
fields_to_extract = get_cached_model_fields(first_field.type
File “C:\Users\USER\AppData\Local\NVIDIA\ChatWithRTX\env_nvd_rag\lib\site-packages\fastapi_compat.py”, line 657, in get_cached_model_fields
return get_model_fields(model)
File “C:\Users\USER\AppData\Local\NVIDIA\ChatWithRTX\env_nvd_rag\lib\site-packages\fastapi_compat.py”, line 284, in get_model_fields
return [
File “C:\Users\USER\AppData\Local\NVIDIA\ChatWithRTX\env_nvd_rag\lib\site-packages\fastapi_compat.py”, line 285, in
ModelField(field_info=field_info, name=name)
File “”, line 6, in init
File “C:\Users\USER\AppData\Local\NVIDIA\ChatWithRTX\env_nvd_rag\lib\site-packages\fastapi_compat.py”, line 110, in post_init
self._type_adapter: TypeAdapter[Any] = TypeAdapter(
File “C:\Users\USER\AppData\Local\NVIDIA\ChatWithRTX\env_nvd_rag\lib\site-packages\pydantic\type_adapter.py”, line 167, in init
core_schema = _get_schema(type, config_wrapper, parent_depth=_parent_depth + 1)
File “C:\Users\USER\AppData\Local\NVIDIA\ChatWithRTX\env_nvd_rag\lib\site-packages\pydantic\type_adapter.py”, line 80, in get_schema
schema = gen.generate_schema(type
File “C:\Users\USER\AppData\Local\NVIDIA\ChatWithRTX\env_nvd_rag\lib\site-packages\pydantic_internal_generate_schema.py”, line 448, in generate_schema
schema = self._generate_schema(obj)
File “C:\Users\USER\AppData\Local\NVIDIA\ChatWithRTX\env_nvd_rag\lib\site-packages\pydantic_internal_generate_schema.py”, line 674, in _generate_schema
return self._annotated_schema(obj)
File “C:\Users\USER\AppData\Local\NVIDIA\ChatWithRTX\env_nvd_rag\lib\site-packages\pydantic_internal_generate_schema.py”, line 1496, in _annotated_schema
schema = self._apply_annotations(source_type, annotations)
File “C:\Users\USER\AppData\Local\NVIDIA\ChatWithRTX\env_nvd_rag\lib\site-packages\pydantic_internal_generate_schema.py”, line 1610, in _apply_annotations
schema = get_inner_schema(source_type)
File “C:\Users\USER\AppData\Local\NVIDIA\ChatWithRTX\env_nvd_rag\lib\site-packages\pydantic_internal_schema_generation_shared.py”, line 82, in call
schema = self._handler(__source_type)
File “C:\Users\USER\AppData\Local\NVIDIA\ChatWithRTX\env_nvd_rag\lib\site-packages\pydantic_internal_generate_schema.py”, line 1703, in new_handler
schema = metadata_get_schema(source, get_inner_schema)
File “C:\Users\USER\AppData\Local\NVIDIA\ChatWithRTX\env_nvd_rag\lib\site-packages\pydantic_internal_generate_schema.py”, line 1699, in
lambda source, handler: handler(source)
File “C:\Users\USER\AppData\Local\NVIDIA\ChatWithRTX\env_nvd_rag\lib\site-packages\pydantic_internal_generate_schema.py”, line 1574, in inner_handler
File “C:\Users\USER\AppData\Local\NVIDIA\ChatWithRTX\env_nvd_rag\lib\site-packages\pydantic_internal_generate_schema.py”, line 694, in _generate_schema
return self.match_type(obj)
File “C:\Users\USER\AppData\Local\NVIDIA\ChatWithRTX\env_nvd_rag\lib\site-packages\pydantic_internal_generate_schema.py”, line 777, in match_type
return self._match_generic_type(obj, origin)
File “C:\Users\USER\AppData\Local\NVIDIA\ChatWithRTX\env_nvd_rag\lib\site-packages\pydantic_internal_generate_schema.py”, line 801, in _match_generic_type
return self._union_schema(obj)
File “C:\Users\USER\AppData\Local\NVIDIA\ChatWithRTX\env_nvd_rag\lib\site-packages\pydantic_internal_generate_schema.py”, line 988, in _union_schema
choices.append(self.generate_schema(arg))
File “C:\Users\USER\AppData\Local\NVIDIA\ChatWithRTX\env_nvd_rag\lib\site-packages\pydantic_internal_generate_schema.py”, line 781, in match_type
return self._unknown_type_schema(obj)
File “C:\Users\USER\AppData\Local\NVIDIA\ChatWithRTX\env_nvd_rag\lib\site-packages\pydantic_internal_generate_schema.py”, line 377, in _unknown_type_schema
raise PydanticSchemaGenerationError(
pydantic.errors.PydanticSchemaGenerationError: Unable to generate pydantic-core schema for <class ‘starlette.requests.Request’>. Set arbitrary_types_allowed=True in the model_config to ignore this error or implement __get_pydantic_core_schema__ on your type to fully support it.
