Connection Issue while connecting Velodyne Lidar VLP-16
Software Version
[*] DRIVE OS 6.0.8.1
DRIVE OS 6.0.6
DRIVE OS 6.0.5
DRIVE OS 6.0.4 (rev. 1)
DRIVE OS 6.0.4 SDK
other
Target Operating System
[*] Linux
QNX
other
Hardware Platform
[*] DRIVE AGX Orin Developer Kit (940-63710-0010-200)
other
SDK Manager Version
1.9.3.10904
[*] other
Host Machine Version
[*] native Ubuntu Linux 20.04 Host installed with DRIVE OS Docker Containers
other
I am facing issues while running ./sample_lidar_replay in Nvidia Drive. The Code which we are running is ./sample_lidar_replay --protocol=lidar.socket --params=device=VELO_VLP16,ip=192.168.1.201,port=2368,scan-frequency=10
In IP I have also tried 192.168.1.22
I have attached some screenshots of the same for the reference.
Dear @prit.shah,
Could you confirm if you can open lidar configuration page using used lidar IP like in page 25/26 in https://velodynelidar.com/wp-content/uploads/2019/12/63-9243-Rev-E-VLP-16-User-Manual.pdf
Did you change lidar IP?
Could you share complete log of the sample?
Thanks for your reply,
Yes I can open lidar configuration page in Host PC but I am unable to open the same in NVIDIA Drive AGX Orin.
In Settings(IPV4) the IP of Lidar is 192.168.1.22
I have attached the screenshot of the output.
Also we are not getting any eth0 or add anything in network manager.
Dear @prit.shah,
Can you share the lidar connection pictures, lidar configuration page picture and ifconfig output.
Please find the images of Ifconfig and Lidar Connection below,
Please find Lidar Configuration page in this thread.
Dear @prit.shah,
Are you able to ping Lidar from target? Could you check if DriveWorks SDK Reference: Basic Recording helps?
I see mgbe1_0 interface has IP? Did you set it?
I see in configuration page lidar IP is 192.168.1.201. May I know where do you see 192.168.1.22?
Hello, Thanks for the help it has solved my issue.
Dear @prit.shah,
Glad to hear the issue is fixed. Could you share what was the mistake?
We have connected the Lidar to Router and that router we are connecting to the Drive. By this we are running Velodyne Lidar.
