Connection Jetson TX2 with Olimexino STM32
I have writen a code for camera pose estimation to detect aruco marker and its working fine. But, I am receiving the coordinates (X,Y,Z) real time on terminal window for aruco tracking. I would like to send these real time values to an olimexino board to build a connection with Jetson.I would like to ask the ways that there are as to do that.Please provide me some steps.
Thanks for the consideration.
You can send the data through the network.
I’m not sure which system is running on the olimexino .
But for Jetson, you can use the standard socket code for the linux.
Oooh I did not know that I can do via network.I was thinking that can do that via CAN ports also.
You can give it a try. It should be similar to the general Linux use case.
