I have installed the AutoML Tao Toolkit API using the bare metal setup instructions from the documentation. I am trying to run the classification notebook from here for running AutoML experiments.
tao-getting-started_v5.2.0/notebooks/tao_api_starter_kit/api/classification.ipynb
While executing the below cell
# Exchange NGC_API_KEY for JWT
data = json.dumps({"ngc_api_key": ngc_api_key})
response = requests.post(f"{host_url}/api/v1/login", data=data)
assert response.status_code in (200, 201)
assert "user_id" in response.json().keys()
user_id = response.json()["user_id"]
print("User ID",user_id)
assert "token" in response.json().keys()
token = response.json()["token"]
print("JWT",token)
# Set base URL
base_url = f"{host_url}/api/v1/user/{user_id}"
print("API Calls will be forwarded to",base_url)
headers = {"Authorization": f"Bearer {token}"}
I am getting the following error
ConnectionRefusedError Traceback (most recent call last)
File /usr/lib/python3/dist-packages/urllib3/connection.py:159, in HTTPConnection._new_conn(self)
158 try:
--> 159 conn = connection.create_connection(
160 (self._dns_host, self.port), self.timeout, **extra_kw
161 )
163 except SocketTimeout:
File /usr/lib/python3/dist-packages/urllib3/util/connection.py:84, in create_connection(address, timeout, source_address, socket_options)
83 if err is not None:
---> 84 raise err
86 raise socket.error("getaddrinfo returns an empty list")
File /usr/lib/python3/dist-packages/urllib3/util/connection.py:74, in create_connection(address, timeout, source_address, socket_options)
73 sock.bind(source_address)
---> 74 sock.connect(sa)
75 return sock
ConnectionRefusedError: [Errno 111] Connection refused
During handling of the above exception, another exception occurred:
NewConnectionError Traceback (most recent call last)
File /usr/lib/python3/dist-packages/urllib3/connectionpool.py:666, in HTTPConnectionPool.urlopen(self, method, url, body, headers, retries, redirect, assert_same_host, timeout, pool_timeout, release_conn, chunked, body_pos, **response_kw)
665 # Make the request on the httplib connection object.
--> 666 httplib_response = self._make_request(
667 conn,
668 method,
669 url,
670 timeout=timeout_obj,
671 body=body,
672 headers=headers,
673 chunked=chunked,
674 )
676 # If we're going to release the connection in ``finally:``, then
677 # the response doesn't need to know about the connection. Otherwise
678 # it will also try to release it and we'll have a double-release
679 # mess.
File /usr/lib/python3/dist-packages/urllib3/connectionpool.py:388, in HTTPConnectionPool._make_request(self, conn, method, url, timeout, chunked, **httplib_request_kw)
387 else:
--> 388 conn.request(method, url, **httplib_request_kw)
390 # Reset the timeout for the recv() on the socket
File /usr/lib/python3.8/http/client.py:1256, in HTTPConnection.request(self, method, url, body, headers, encode_chunked)
1255 """Send a complete request to the server."""
-> 1256 self._send_request(method, url, body, headers, encode_chunked)
File /usr/lib/python3.8/http/client.py:1302, in HTTPConnection._send_request(self, method, url, body, headers, encode_chunked)
1301 body = _encode(body, 'body')
-> 1302 self.endheaders(body, encode_chunked=encode_chunked)
File /usr/lib/python3.8/http/client.py:1251, in HTTPConnection.endheaders(self, message_body, encode_chunked)
1250 raise CannotSendHeader()
-> 1251 self._send_output(message_body, encode_chunked=encode_chunked)
File /usr/lib/python3.8/http/client.py:1011, in HTTPConnection._send_output(self, message_body, encode_chunked)
1010 del self._buffer[:]
-> 1011 self.send(msg)
1013 if message_body is not None:
1014
1015 # create a consistent interface to message_body
File /usr/lib/python3.8/http/client.py:951, in HTTPConnection.send(self, data)
950 if self.auto_open:
--> 951 self.connect()
952 else:
File /usr/lib/python3/dist-packages/urllib3/connection.py:187, in HTTPConnection.connect(self)
186 def connect(self):
--> 187 conn = self._new_conn()
188 self._prepare_conn(conn)
File /usr/lib/python3/dist-packages/urllib3/connection.py:171, in HTTPConnection._new_conn(self)
170 except SocketError as e:
--> 171 raise NewConnectionError(
172 self, "Failed to establish a new connection: %s" % e
173 )
175 return conn
NewConnectionError: <urllib3.connection.HTTPConnection object at 0x7f90643c28e0>: Failed to establish a new connection: [Errno 111] Connection refused
MaxRetryError Traceback (most recent call last)
File /usr/local/lib/python3.8/dist-packages/requests/adapters.py:486, in HTTPAdapter.send(self, request, stream, timeout, verify, cert, proxies)
485 try:
--> 486 resp = conn.urlopen(
487 method=request.method,
488 url=url,
489 body=request.body,
490 headers=request.headers,
491 redirect=False,
492 assert_same_host=False,
493 preload_content=False,
494 decode_content=False,
495 retries=self.max_retries,
496 timeout=timeout,
497 chunked=chunked,
498 )
500 except (ProtocolError, OSError) as err:
File /usr/lib/python3/dist-packages/urllib3/connectionpool.py:720, in HTTPConnectionPool.urlopen(self, method, url, body, headers, retries, redirect, assert_same_host, timeout, pool_timeout, release_conn, chunked, body_pos, **response_kw)
718 e = ProtocolError("Connection aborted.", e)
--> 720 retries = retries.increment(
721 method, url, error=e, _pool=self, _stacktrace=sys.exc_info()[2]
722 )
723 retries.sleep()
File /usr/lib/python3/dist-packages/urllib3/util/retry.py:436, in Retry.increment(self, method, url, response, error, _pool, _stacktrace)
435 if new_retry.is_exhausted():
--> 436 raise MaxRetryError(_pool, url, error or ResponseError(cause))
438 log.debug("Incremented Retry for (url='%s'): %r", url, new_retry)
MaxRetryError: HTTPConnectionPool(host='172.x.x.x', port=32080): Max retries exceeded with url: /api/v1/login (Caused by NewConnectionError('<urllib3.connection.HTTPConnection object at 0x7f90643c28e0>: Failed to establish a new connection: [Errno 111] Connection refused'))
Cell In[6], line 3
1 # Exchange NGC_API_KEY for JWT
2 data = json.dumps({"ngc_api_key": ngc_api_key})
----> 3 response = requests.post(f"{host_url}/api/v1/login", data=data)
4 assert response.status_code in (200, 201)
5 assert "user_id" in response.json().keys()
File /usr/local/lib/python3.8/dist-packages/requests/api.py:115, in post(url, data, json, **kwargs)
103 def post(url, data=None, json=None, **kwargs):
104 r"""Sends a POST request.
105
106 :param url: URL for the new :class:`Request` object.
112 :rtype: requests.Response
113 """
--> 115 return request("post", url, data=data, json=json, **kwargs)
File /usr/local/lib/python3.8/dist-packages/requests/api.py:59, in request(method, url, **kwargs)
55 # By using the 'with' statement we are sure the session is closed, thus we
56 # avoid leaving sockets open which can trigger a ResourceWarning in some
57 # cases, and look like a memory leak in others.
58 with sessions.Session() as session:
---> 59 return session.request(method=method, url=url, **kwargs)
File /usr/local/lib/python3.8/dist-packages/requests/sessions.py:589, in Session.request(self, method, url, params, data, headers, cookies, files, auth, timeout, allow_redirects, proxies, hooks, stream, verify, cert, json)
584 send_kwargs = {
585 "timeout": timeout,
586 "allow_redirects": allow_redirects,
587 }
588 send_kwargs.update(settings)
--> 589 resp = self.send(prep, **send_kwargs)
591 return resp
File /usr/local/lib/python3.8/dist-packages/requests/sessions.py:703, in Session.send(self, request, **kwargs)
700 start = preferred_clock()
702 # Send the request
--> 703 r = adapter.send(request, **kwargs)
705 # Total elapsed time of the request (approximately)
706 elapsed = preferred_clock() - start
File /usr/local/lib/python3.8/dist-packages/requests/adapters.py:519, in HTTPAdapter.send(self, request, stream, timeout, verify, cert, proxies)
515 if isinstance(e.reason, _SSLError):
516 # This branch is for urllib3 v1.22 and later.
517 raise SSLError(e, request=request)
--> 519 raise ConnectionError(e, request=request)
521 except ClosedPoolError as e:
522 raise ConnectionError(e, request=request)
ConnectionError: HTTPConnectionPool(host='172.x.x.x', port=32080): Max retries exceeded with url: /api/v1/login (Caused by NewConnectionError('<urllib3.connection.HTTPConnection object at 0x7f90643c28e0>: Failed to establish a new connection: [Errno 111] Connection refused'))
I tried to run the below command by following this thread
$ kubectl edit services tao-toolkit-api-service
but i get the below error
Unable to connect to the server: dial tcp 172.x.x.x:6443: i/o timeout
Would really appreciate any help regarding this issue. Thanks.
